Hi, I have a bunch of videos that I wanna convert from MKV to MPEG-4 to watch on my cellphone, but the video has softsubs that are turned on by default, and they stay when I convert, but I want to remove them completely, so how do you do that?
BTW, I'm using FormatFactory.
Thanks in advance
	Remove the softsubs using mkvtoolnix (mkvmergegui).
	Or, set Subtitle Stream Index to "None" in Format Factory video encoding settings (normally, it is set to Default).
	If I remove Subtitles using mkvmerge gui, then format factory cannot convert the file properly into vob. Also, I've tried setting Subtitle Stream Index to "None" in Format Factory video encoding settings, but the subtitles still don't get removed, how can I remove it?
 By the way, my subtitile details is : S_VOBSUB (ID 4, type: subtitiles)
	I would guess it's because of header compression in mkv. Try the old mkvmergegui 3.4 or try disable header compression in mkvmergegui 4.
	Yup - removing subtitles with mkvmerge (MKV Toolkit) and then FF converting works fine. As mentioned above make sure the option in mkvmerge (Ctrl-P or File->Options) "Disable header removal compression for audio and video tracks by default" is checked.
 It is a 2-4 min overhead (for a standard ~700MB mkv) and a space issue, but it is clean and works. Just remember that FormatFactory will take two passes to process this file for some reason. The first pass will be very slow and produce a 40-60MB file. The second one will go normally.
 Also noticed FormatFactory will not play preview the file in the option window, where the crop options are available
	Hello!
 I tried all the above, but it didnt work. But I noticed that in Format Factory I could change the font that would be put on the video, so I wondered if there was an invisible font with blank letters. This excist: http://www.angelfire.com/pr/pgpf/if.html. Download the invisible font and go to format factory. Select the file you want to convert and go to options (in the upper bar.) Options > Font > Set font to invisible.tff.
 This worked for me, I hope it will work for other too
  Converting MKV (Get rid of subtitles)By kpat99 in forum Video ConversionReplies: 3Last Post: 4th Feb 2012, 09:50
  Remove subtitles from MKV when converting with TMPEGEncBy ikarishinji41 in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 11:21
  Converting MKV subtitles to SRTBy Xpenguin17 in forum SubtitleReplies: 7Last Post: 9th Oct 2009, 17:59
  converting newer mkv files w/ subtitlesBy Dolly in forum MacReplies: 4Last Post: 26th Jul 2009, 16:52
  Converting mkv to dvd (or whatever) but it MUST have subtitles...By pwhyles in forum Newbie / General discussionsReplies: 12Last Post: 14th Feb 2008, 16:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
