    May 2009
    Hi. I have created a dvd with 2 avi files using DIKO.
    The 1st time I encoded - the temp files got deleted [I think].
    The second time I went to configuration and unchecked the 'delete temp files' option, and redid encode - however during both 1st and second time of encoding I was unable to see any temp files in the temp folder, nor did I see any disc images.
    Also the encode log was not saved.
    What to do as it is now eating up my memory, without me knowing what happened to the files.
    I have the latest version of DIKO 2.47
    May 2009
    Sorry, my bad. I figured it out. It seems in vista when you go into the C:\Program Files\DIKO\Temp folder you have to click on 'Compatibility Files' in order to view the temp files created by DIKO. I thought the program was nuts, turns out its the system
