1:1 VGA: Is used when your source was encoded for your computer(streaming video and things of that nature)
4:3 525 line (NTSC): Is used when your source was encoded to be played on a TV.
So the DivX that can be found on the net, are they in 1:1 VGA or in 4:3? How do I know?
Because I encoded a VCD using a Source Aspect Ration of 4:3 and I'm not sure but I think the aspect ratio on the TV screen is a little off. It's hard to judge since the difference between 1:1 and 4:3 must not be that big, but I suspect that the image is a little stretched vertically.
So does it mean that I should put the "Source Aspect Ratio" to 1:1 VGA when I convert DivX DVD rips since the person who ripped them probably put an aspect ratio to watch it on a computer?
And once the .mpg file is encoded, should it look right on my computer or is it normal if it looks a little off and it's on my TV that the ratio will be right? :-?
Thank you for your help,
Regards,
Mikhail
Results 1 to 1 of 1
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
CloneDVD aspect ration problem
By godftw in forum DVD RippingReplies: 13Last Post: 6th Aug 2010, 16:13 -
Aspect Ration ?'s (Avs video converter)
By VicSedition in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2010, 20:59 -
how to get 704x480 with 16:9 Aspect Ration in virtual dub mod
By afcoff in forum Video ConversionReplies: 6Last Post: 4th Jun 2009, 17:55 -
Aspect ration problems when encoding in VDub
By sd_smoker in forum Newbie / General discussionsReplies: 12Last Post: 5th Jul 2008, 11:24
