    Jul 2009
    Macedonia, the Former Yugoslav Republic of
    I am new here so first I need to tell you that I dont know english very good.
    I have some problem with nero so here is the eror log.
    When I put empty DVD it burns several minutes and than it stops and show the eror.
    Windows XP 5.1
    IA32
    WinAspi: -
    NT-SPTI used
    Nero Version: 9.0.9.100
    Internal Version: 9, 0, 9, 100
     (Nero Express)
    Recorder:             <ASUS DRW-1608P3S>        Version: 1.24 - HA 1 TA 0 - 9.0.9.100
     Adapter driver:      <IDE>                     HA 1
     Drive buffer  :      2000kB
     Bus Type      :      default
    CD-ROM:               <ASUS     DRW-1608P3S     >Version: 1.24 - HA 1 TA 0 - 9.0.9.100
    === Scsi-Device-Map ===
    CdRomPeripheral      : ASUS DRW-1608P3S                 atapi Port 0 ID 1  DMA: On
    DiskPeripheral       : Maxtor 6V200E0                   atapi Port 1 ID 0  DMA: On
    === CDRom-Device-Map ===
    ASUS DRW-1608P3S           E:   CdRom0
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE           : 0
    Physical memory     : 2047MB (2096432kB)
    Free physical memory: 1434MB (1469392kB)
    Memory in use       : 29 %
    Uncached PFiles: 0x0
    Use Inquiry    : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    6.7.2009
    UDF compilation
    04:29:22	#1 Text 0 File SCSIPTICommands.cpp, Line 450
    	LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    04:29:22	#2 Text 0 File Isodoc.cpp, Line 6789
    	UDF document burn settings
    	Determine maximum speed : FALSE
    	Simulate                : FALSE
    	Write                   : TRUE
    	Finalize CD             : FALSE
    	Multisession            : TRUE
    	Multisession type:      : Start multisession
    	Burning mode            : DAO
    	Mode                    : 1
    	UDF Mode                : pure
    	UDF Options             : automatic
    	UDF Revision            : 1.02
    	UDF Partition Type      : physical
    04:29:22	#3 Text 0 File Burncd.cpp, Line 3563
    	Turn on Disc-At-Once, using DVD media
    04:29:23	#4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
    	FS Settings: using validator 'CUDFSettingsValidatorDVD'
    	ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
    	Changing UDF revision from '1.02' to '1.02'
    04:29:23	#5 Text 0 File DlgWaitCD.cpp, Line 312
    	Last possible write address on media:  2297887 (510:38.37, 4488MB)
    	Last address to be written:            1614399 (358:45.24, 3153MB)
    04:29:23	#6 Text 0 File DlgWaitCD.cpp, Line 324
    	Write in overburning mode: NO (enabled: CD)
    04:29:23	#7 Text 0 File DlgWaitCD.cpp, Line 2951
    	Recorder: ASUS DRW-1608P3S, Media type: DVD-R
    	 Disc Manufacturer ID: <PRINCO> <RGM1>
    	 Disc Application Code: 64, Disc Physical Code: 193
    04:29:23	#8 Text 0 File DlgWaitCD.cpp, Line 499
    	>>> Protocol of DlgWaitCD activities: <<<
    04:29:23	#9 Text 0 File ThreadedTransferInterface.cpp, Line 756
    	Setup items (after recorder preparation)
    	 0: TRM_DATA_MODE1 ()
    	    2 indices, index0 (150) not provided
    	    original disc pos #0 + 1614400 (1614400) = #1614400/358:45.25
    	    relocatable, disc pos for caching/writing not required/ required
    	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1614400 blocks [E: ASUS DRW-1608P3S]
    04:29:27	#10 Text 0 File ThreadedTransferInterface.cpp, Line 958
    	Prepare [E: ASUS DRW-1608P3S] for write in CUE-sheet-DAO
    	DAO infos:
    	 MCN: ""
    	 TOCType: 0x00; Session Closed, disc not fixated
    	 Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
    	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    3306291200, ISRC ""
    	DAO layout:
    	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
    	        0 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
    	        0 |        1 |   0 |    0x41 |        0 |        0 | 0x00
    	        0 |        1 |   1 |    0x41 |  1614400 |        0 | 0x00
    	  1614400 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
    04:29:27	#11 Text 0 File SCSIPTICommands.cpp, Line 240
    	SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
    04:29:27	#12 Text 0 File Burncd.cpp, Line 4362
    	Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
    04:29:27	#13 Phase 24 File dlgbrnst.cpp, Line 1767
    	Caching of files started
    04:29:27	#14 Text 0 File Burncd.cpp, Line 4484
    	Cache writing successful.
    04:29:27	#15 Phase 25 File dlgbrnst.cpp, Line 1767
    	Caching of files completed
    04:29:27	#16 Phase 36 File dlgbrnst.cpp, Line 1767
    	Burn process started at 6x (8.310 KB/s)
    04:29:27	#17 Text 0 File ThreadedTransferInterface.cpp, Line 2675
    	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    04:29:27	#18 Text 0 File DVDR.cpp, Line 3259
    	Recording mode: Sequential Recording Mode for Multisession
    04:29:27	#19 Text 0 File DVDR.cpp, Line 3413
    	Start write address at LBA 0
    	DVD high compatibility mode: Yes
    04:29:27	#20 SPTI -1066 File SCSIPassThrough.cpp, Line 215
    	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
    	CDB Data:   0xAC 00 00 00 00 00 00 00 00 64 00 00
    	Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
    	Sense Code: 0x24
    	Sense Qual: 0x00
    	Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
    	Buffer x04da2040: Len x648
    04:29:27	#21 Text 0 File Cdrdrv.cpp, Line 10187
    	---- Disc Structure: Physical Format Information (00h) ----
    	Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    	 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
    	 Disc Size: 120 mm,      Maximum Transfer Rate: <not specified> (F h)
    	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
    	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
    	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    	 Outer Limit of Data Recordable Area:          0 h
    	 Data in Burst Cutting Area (BCA) does not exist
    	  Revision number of maximum recording speed: 6.0
    	  Revision number of minimum recording speed: -
    	  Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
    	  Class: 0,  Extended part version: 33
    	  Start PSN of the Extra Border Zone: 0 h
    	  Start PSN of Physical format information blocks in Extra Border Zone: 0 h
    	 Media Specific [16..783]:
    	    00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00    .`...0@P...!....
    	    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
    	    1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
    	    01 40 C1 FD 9E D8 52 00 - 02 36 0D 11 88 99 90 00    .@....R..6......
    	    03 50 52 49 4E 43 4F 00 - 04 52 47 4D 31 00 00 00    .PRINCO..RGM1...
    	    05 00 00 00 00 00 00 00 - 06 06 0F 11 98 89 90 00    ................
    	    07 08 80 00 00 00 00 00 - 08 06 18 0B 11 07 07 00    ................
    	    09 84 08 0F 0E 6E 08 00 - 0A 00 00 00 00 00 10 00    .....n..........
    	    0B 00 00 00 00 00 00 00 - 0C 00 00 00 00 00 00 00    ................
    	    0D 00 00 00 00 00 00 00 - 0E 0A 24 35 2F 29 1A 00    ..........$5/)..
    	    0F 50 1B 29 17 97 B5 00 - 10 88 80 00 00 00 00 00    .P.)............
    	    11 00 00 00 00 00 00 00 - 12 09 2E 37 2F 29 19 00    ...........7/)..
    	    13 50 1B 29 17 97 B5 00 - 14 88 80 00 00 00 00 00    .P.)............
    	    15 00 00 00 00 00 00 00 - 16 09 3F 44 3D 24 29 00    ..........?D=$).
    	    17 60 1F 2F 1D 97 B5 00 - 18 88 84 00 04 00 04 00    .`./............
    	    19 00 00 00 00 00 00 00 - 1A 08 57 46 42 27 24 00    ..........WFB'$.
    	    1B 70 1F 2B 0F AA B5 00 - 1C 88 84 00 04 00 04 00    .p.+............
    04:29:27	#22 Text 0 File DVDR.cpp, Line 3551
    	Reserved Track size: 1614400 (18A240h, 3153MB) -> return code 0
    04:29:27	#23 Text 0 File ThreadedTransfer.cpp, Line 273
    	Pipe memory size 83836800
    04:29:27	#24 Text 0 File CUDFTransferItem2.cpp, Line 660
    	GenUDF2 FS Layout:
    	    Sectors to be written: 1614400
    	            Session Start: Sector 0
    	         Volume Structure: Sector [0, 256] (257 Sectors)
    	                Meta Data: Sector [257, 277] (21 Sectors)
    	                     Data: Sector [278, 1614102] (1613825 Sectors)
    	               After Data: Sector [1614103, 1614111] (9 Sectors)
    	            Trailer Track: Sector [1614112, 1614399] (288 Sectors)
    	GenUDF2 Parameters:
    	                 PrepTime: 07-06-2009 04:29:23
    	             UDF Revision: 1.02
    	       UDF Partition Type: Physical
    	         UDF Special Mode: None
    	         Bytes per Sector: 2048
    	            Session Start: 0
    	 Physical Partition Start: -1
    	           Total Capacity: 2297888
    	       Multi Session Mode: Begin
    	                Disc Type: DVD-R
    	                 OS Class: 0
    	                Volume ID: My Disc
    	     Allow Unicode Labels: 0
    	      Duplicate Meta Data: 1
    	             MS Info File: 04D0A100
    	        VMS Rollback File: 00000000
    	        Create ISO bridge: 0
    	         ECC Block Length: 16
    	    Sparing Packet Length: 32
    	     Allocation Unit Size: 32
    	      Alignment Unit Size: 16
    	            Make Writable: 0
    	              Access Type: Read-only
    04:29:27	#25 Text 0 File Cdrdrv.cpp, Line 1411
    	04:29:27.828 - E: ASUS DRW-1608P3S : Queue again later
    04:30:02	#26 SPTI -1064 File SCSIPassThrough.cpp, Line 215
    	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
    	CDB Data:   0x2A 00 00 00 03 80 00 00 20 00 00 00
    	Sense Code: 0x21
    	Sense Qual: 0x02
    	Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 21 02
    	Buffer x096d0740: Len x10000
    	0x12 92 B9 7C 4D 79 E8 A4 83 A4 AD 6E 90 DB 5E 04
    	0xF2 D5 7C 4B C0 4C 59 57 9B 6D 03 D6 B5 B5 F9 35
    	0xFC 3C 1F 4E E9 E4 96 14 D8 7F FD 1B 1C 32 0F 07
    04:30:02	#27 CDR -1064 File Writer.cpp, Line 306
    	Invalid block address
    	E: ASUS DRW-1608P3S
    04:30:02	#28 Phase 133 File dlgbrnst.cpp, Line 1767
    	Writing short lead-out
    04:37:23	#29 Text 0 File DVDR.cpp, Line 3819
    	EndDAO: Last written address was 895 (37Fh)Close track 1, ret: 0
    	Close Session/Border, function 2, track: 3, finalize disc: NO, ret: 0
    04:37:23	#30 Text 0 File DVDPlusDualLayer.cpp, Line 1424
    	SetDriveCaps: Set LAST LBA of layer 1 to 0
    04:37:24	#31 Phase 38 File dlgbrnst.cpp, Line 1767
    	Burn process failed at 6x (8.310 KB/s)
    04:37:24	#32 Text 0 File SCSIPTICommands.cpp, Line 287
    	SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    04:37:30	#33 Text 0 File Cdrdrv.cpp, Line 11444
    	DriveLocker: UnLockVolume completed
    04:37:30	#34 Text 0 File SCSIPTICommands.cpp, Line 450
    	UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    I hope you will help me. Thnks.
    Nov 2004
    Las Vegas
    KristijanR,
    The problem is the low quality blank disks you're using:
    To get good burns, you have to use good media.
    You can try burning at a lower speed (you already know 6x isn't working so good), but realistically, the best you can hope for with this media is a borderline-usable burn...and probably not even that.
    If you can find Taiyo Yuden or Verbatim disks, your burns would be much better, and your life would be a lot easier.
    I should mention that the burn log says you were burning the disk as multisession. Unless you meant to do that, you should disable that option. Multisession for data disks is frequently more trouble than it's worth, and will make dvd-video disks unplayable.
    Welcome to VideoHelp.
