whenever i try to encode to xvid with using virtual dub it puts no profile even thought i put advenced simple @ L5 and once its encoded i try to play its only sound no video. i unistaled my klite codec pack and reinstall it but it still didnt work here's couple of screenshot for people who didnt understand me. i tried with using ffdshow encoder but it sets to simple @ L1 please help
Are you making a two pass encode? The first pass just generates a 'dummy' file for the encoder instructions. The second pass encodes the video. I usually use 'Unrestricted' 'single pass' mode for a setting and a Quantizer setting of '2' for good quality, but slightly larger filesize. That's the quick and easy way. If you want to control filesize and quality, then the two pass method may be a better choice. But you will have to manually select the second pass setting. (The same box as 'Twopass -1st pass' but choose 'Twopass 2nd pass')
Xvid should keep the settings you choose till you change them. Maybe K-lite has damaged the codec.
If so, dump K-lite if you can get it off your computer with no further damage, then uninstall and reinstall the latest Xvid version.
You set the codec to "twopass - 1st pass", Save as AVI, then set the codec to "twopass - 2nd pass" and Save as AVI again. After the first pass the AVI will contain no video (it will be all black). During the second pass Xvid uses the log from the first pass to best allocate bits to meet your requested average bitrate.Originally Posted by caner12
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 15:12 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47 -
xvid encoding in Virtual Dub, stats file?
By Xavier in forum Video ConversionReplies: 4Last Post: 10th Feb 2009, 08:46 -
how to set max bitrate(xvid virtual dub)
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Feb 2008, 08:54
