Is it possible to directly join 3 clips with Virtual DubMod? If so, can you give me the click by click recipe?
I can join 2 clips with Virtual DubMod.
Recipe:
1) file> open> part 2
2) file>append segment>part 1
3) file> open> part 1
4) file> append segment> part 2
5) file>save as>File name:type merge (choose "Direct Stream Copy" under Video Mode)
If your video files are in sequence and named the same, VDM will automatically append them when you open the first file in the folder.
Video1.avi
Video2.avi
Video3.avi
These will become a single video, then you just create a new filename and save in Direct Stream Copy. But the files have to be exactly the same. You can change the auto append setting in the open dialog page. Or you could open the first file if they are named different, then append the second, then append the third. -
I'll try it:
I once tried to do this and they joined in the wrong order, but maybe I did something wrong.Open the first videoclip, File->Open video file
Select File->Append Video Segment to open and add other videoclips. Repeat this step until you have add all you videoclips.
Select under Audio->Direct Stream Copy.
Select also under Video->Direct Stream Copy.
Last hit File->Save AVI and save the new joined movieclip. -
Computers count differently.
If you labeled them:
video1.avi
video5.avi
video10.avi
They would come out as:
video1.avi
video10.avi
video5.avi
Use 01, 02, 03 or a, b, c, d. -
Not quite.If your video files are in sequence and named the same, VDM will automatically append them when you open the first file in the folder.
Video1.avi
Video2.avi
Video3.avi
You have to open the first file, then append the second file. The third will automatically append (unless you disable the option in the Append Avi Segment dialog).
Is it possible to join clips in iMovie HD
By piperpilot12w in forum MacReplies: 2Last Post: 3rd Mar 2010, 17:30 -
Question about best Xvid codec to use with Virtual DubMod
By jimdagys in forum Video ConversionReplies: 1Last Post: 29th Nov 2009, 11:04 -
question about converting wmv to avi (xvid) using Virtual Dubmod
By jimdagys in forum Video ConversionReplies: 5Last Post: 16th Apr 2008, 15:16 -
How do i join 2 .avi clips?
By vandaLo in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 20:52 -
How do i join these kind of clips?
By vandaLo in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2007, 13:50
