I have an .mpg file which plays the video but no sound on my Philips DVP-3140/37 DivX player.
I tried to convert it to mp3 but it doesn't work either.
Does anyone know how can I fix this to play sound correctly?
TIA
Results 1 to 16 of 16
Originally Posted by Baldrick
I did not convert to avi with mp3 audio -- just mpg with mp3 audio.
When I load the mpg file in AutoGK it says no video stream found. -
This may seem like a silly question, but have you checked you audio output connections from your DVD player to your TV/Surround sound system are connected, they may have disconnected or come loose through movement, it happens.
Another thing to try, why don't you demux (separate) the audio, & try to play the audio file on it's own on your DVD player, this may isolate the problem to just the audio file. -
Originally Posted by G)-(OST
Originally Posted by G)-(OST -
So what you are saying is, that the AC3 audio file in the mpeg video file does not play sound on your DVD player, but when you play the AC3 audio file in an AVI video file, it plays the sound.
My next question is, why can't you leave it as AVI if it works on your DVD player? -
Originally Posted by guns1inger
b) I pretty much assumed that his DVD player plays raw mpeg files since my one does. -
I will try to rename the mpg to vob and see if that will work, although if the sound didn't come out properly before in a mpg container I would think the sound wouldnt' come out properly either in a vob container. -
Basically, no sounds comes out of the mpg file and I do not have an AVI format of the same video content.
I would be content to re-encode the mpg file into an XviD at the highest possible setting to retain optimal quality but AutoGK says "No video stream found" when I load the mpg file. -
So, face it: your DVD player doesn't play the audio in MPG files with AC3 or MP3 audio. Did you try MP2 audio?
Originally Posted by jagabo
I tried MP2 audio and it worked.
Thanks!
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Can philips dvp 3588 dvd player,play a divx file of 720p resolution?
By jazzymegatron in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Jul 2010, 10:06 -
mpg with sound that doesn't play
By sivodsi in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2010, 08:38 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
Panasonic DMR-EH56 doesn't play 2nd audiotrack of DIVX-file
By Scotty73 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2007, 11:27
