I have a source MKV file. These are the specs (from MediaInfo):
I would like to convert this file to MP4 playable on PS3 with either softsubs or hardsubs (English).Code:General Format : Matroska File size : 2.92 GiB Duration : 1h 20mn Overall bit rate : 5 175 Kbps Encoded date : UTC 2007-11-13 21:47:54 Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Cover : Yes / Yes / Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 13 frames Muxing mode : Container profile=Unknown@5.1 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 20mn Bit rate : 3 562 Kbps Nominal bit rate : 3 662 Kbps Width : 1 216 pixels Height : 720 pixels Display aspect ratio : 1.689 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.170 Stream size : 2.01 GiB (69%) Writing library : x264 core 56 svn-680 Encoding settings : cabac=1 / ref=10 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=2 / deadzone=9,9 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=10 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=3662 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.7:15.0 Language : English Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1h 20mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 871 MiB (29%) Language : French Text #1 ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Language : English Text #2 ID : 4 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Language : Romanian
I have tried converting this with XviD4PSP and GOTSent but they do not support DTS Audio (I had already converted the subs to SRT format).
Next, I tried extracting the different streams with MKVextractGUI and converting the DTS audio to AAC with foobar2000. All of this worked. Then, I tried to mux the .h264 file, .mp4 (audio) file, and .srt file with YAMB but the conversion didn't yield an output file no matter how many times I tried.
Any suggestions?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Results 1 to 11 of 11
Actually, I would like to hardcode the subtitles in the video.
I have .ass subs with the font files and .srt subs.
Is there any way I could hardcode them into the source .h264 file? -
I have tried that at least 5 different times and the subtitles are never hardcoded in the output file
Yep, avidemux is buggy but don't give up. You have 1000 more free tools to try like AutoMKV, HDConvertToX, Format Factory, Super. Most are guis for ffmpeg or mencoder and should support subtitles.
Or make a custom avisynth script with a subtitle filter(but it's what xvid4psp does...)
(or well I would have give up a long time ago...
this can be a issue with specialized ass files that have odd formatted text.. any alternative way besides converting ass to srt?
MKV -> MP4 for PS3 script?
By atod in forum LinuxReplies: 6Last Post: 10th Feb 2011, 16:38 -
mkv to mp4(ps3) subtitle issues
By HeroSmero in forum Video ConversionReplies: 2Last Post: 3rd Jan 2010, 20:43 -
The Best Xbox 360 and PS3 mkv video converting to mp4 App.
By spyder7777 in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2009, 05:55 -
Large MKV (h264) File to PS3 MP4 without re-encoding
By icue in forum MacReplies: 0Last Post: 29th Sep 2008, 19:14 -
MKV to MP4 for PS3 Error
By Ravlin in forum Video ConversionReplies: 1Last Post: 5th Jul 2008, 18:38
