    Jul 2002
    Can someone recommend a 64 bit RAID card. I need to set up two harddrives as raid 1. The 64 bit cards appear to be scarce
    Feb 2009
    64 bit slot, or 64 bit driver?
    This one is 64 bit slot x86 XP/Vista OS
    http://www.newegg.com/Product/Product.aspx?Item=N82E16816104007 $56USD
    This one is 64 bit slot x64 XP/Vista OS
    http://www.newegg.com/Product/Product.aspx?Item=N82E16816318004 $80USD
    ocgw
    peace
    i7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
    https://forum.videohelp.com/topic368691.html
    Jul 2002
    I'm not quite sure what I need at this point.
    I installed Windows 7 64 bit system onto a 64 bit motherboard.
    I an now trying to find a pci raid card and driver to fit this situation.
    Feb 2009
    OK, 64 bit driver, well any card that has Vista x64 driver support should work, dozens to chose from
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010150410%201193512552&pa...rchResult=True
    ocgw
    peace
    Jul 2002
    to ocgw
    Thanks for your help. I just ordered.
    Feb 2009
    to ocgw
    thx back to you bro', much appreciated
    ocgw
    peace
