Hello everybody!
I'm looking for a camcorder that would shoot quality videos, like the ones in New World Disorder and all those cool Newschool Ski movies. I already have a Sony HDRSR11, with its HD video and pumped up FPS, but it has a hard drive, i can't jump from a big air with my friend cause the video is all distorted, i want to shoot like Jon Hatveit! I know that Mini DV is my best bet, but i need the best quality for the best price, and i don't understand how are they able to slow the video so much and still get stable frame rate.
Thank you in advance guys!
Results 1 to 10 of 10
Low End: Canon HV40 - $850
Middle: Panasonic DMC-GH1 - $1500
Higher End: Canon 5DmkII - $3500
Very High: Red - $20,000
Every one of the cameras above has advantages and disadvantages. There's no perfect camera.
Plus you need a way to stabilize the image from big bumps so it doesn't turn into jello (rolling shutter effect). Also Neutral Density filters for very sunny days
Keeping the image steady is just as important as the camera, even more so. I would look at a low cost Steadytracker stabilizer since you can ski with it and it doesn't require a lot of practice to learn.
http://www.cobracraneusa.com/Camera-Stabilizers.html
Here's 120fps video from the RED camera. You can see how beautiful the slow motion is. At 120 fps you can capture a lot of information.
http://www.vimeo.com/1340684
This video below is great. It uses the $3500 5DmkII, using a stick mounted monopod stabilizer and a 15mm fisheye lens. Appropriate lens and fantastic stabilization is what makes this video so good.
http://vimeo.com/3155182
The Panasonic is $1500 and will shoot 50/60fps at 720p and 25/29.7fps at 1080i
Demo of the GH1
http://vimeo.com/groups/gh1/videos/4714724"Quality is cool, but don't forget... Content is King!" -
They are probably using special high speed cameras that shoot 100 fps or more. Like these:Originally Posted by Maralez
http://www.visionresearch.com/ -
Thanks a lot guys,esp. Soopafresh, but i was thinking in terms of camcorders, not photo cameras. Maybe you have a suggestion how i should render a 30fps shot slowed down to 50% velocity and make it look as smooth as possible?I use Sony Vegas by the way,cause MTS files wreck havoc in anything else.
Shoot 30i, use a smart BOB deinterlacer, and set the frame rate to 30 fps.Originally Posted by Maralez
Shoot 30i, use a smart BOB deinterlacer, and set the frame rate to 30 fps.[/quote]
Could someone please explain this?))))
One more question,when i render a project in Sony vegas,does anyone know the best format (size and quality wise)? I shoot in full HD-1920-1080, and my videos, when i render them in SD end up very blurry. I need a good codec, preferably for avi files, but there are so many, i don't know which one to choose.
Thank you very much -
In a 30i frame (marketing has started calling this 60i) each frame contains two half pictures, called fields, take an 1/60 second intervals. One field is in all the even numbered scanlines, one in all the odd numbered scanlines. When watched on a interlaced TV you see one one field at a time, in sequence. Ie you see 60 fields per second, not 30 frames per second.Originally Posted by Maralez
A dumb bob simply separates the two fields and interpolates the missing lines leaving you with 60 full frames per second. But this leaves sharp horizontal edges bouncing up and down by one scanline (hence the name "bob"). A smart bob analyzes the the frame, or even several frames, and decides which parts of the frame don't need to be deinterlaced, or can fill in with data from adjacent frames.
After bobbing you just tell the editor to assume the frame rate is 30 fps, not 60 fps. This leaves you with slow motion video running at half speed.
Here's a site that describes interlacing and deinterlacing:
http://www.100fps.com/
Here's a sample video that shows some of the more advanced deinterlacers with a very challenging source:
https://forum.videohelp.com/images/guides/p1934885/stockholma_0-520_q3_yadif_mvbobmod_t...mca4_tdtmm.avi
The problem may not be the coded used. It may be that your video was improperly deinterlaced before encoding. One of the simplest deinteracing techniques that many programs use is to simply blur the two fields together. This leaves you with a blurry image with small motions, double exposures with large motions.Originally Posted by Maralez
What codec you use depends on what you plan to do with the video. If it's just for watching Divx or Xvid is a good choice. If you plan on editing it further DV is a good choice. Lagarith or HuffYUV (lossless compression but very big files) are even better. -
Yeah, it's great. Is it appropriate for the ski slopes? Too big and heavy. Wait till you're out there for an hour and the fatigue sets in.Originally Posted by Maralez"Quality is cool, but don't forget... Content is King!"
Advice on dslr camera for shooting vids for youtube
By photoross in forum Newbie / General discussionsReplies: 9Last Post: 6th Feb 2012, 22:31 -
Shooting video
By chrisj in forum Newbie / General discussionsReplies: 2Last Post: 21st Dec 2010, 21:32 -
Best camera for quality action sport films?
By patonb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 27th May 2010, 21:20 -
Sports video - how to add comments
By Minniemae in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 11:52 -
Help with sports action shooting
By cobra jet in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2008, 16:52
