Hello folks,
I have uploaded a FLV video with XML file generated through FLVMDI.EXE. I am still not able to jump to the mid of the video. In order to do that I have to wait for entire to download. Please help me.
Regards,
Results 1 to 9 of 9
...Just a little bit more explanation here...
Please note that I am streaming video on my website. I do not want my users to wait for entire video to download or listen/watch entire video. They should be able to jump/forward to any part of the video. -
And how did you make the flv? What flash player are you using?
I converted MPEG file into FLV using "EasyFLV Free FLV Converter". I am using JW Player on website.
thanks for the guidance. I tried to use super and winff. But same result. This is how I am doing. I have MPEG4 file which I am converting to FLV. After conversion, I am running FLVMDIGUI for XML. I am uploading both files to my website. I am accessing FLV video through JW Player. I am not sure if I am missing any step? you may check my file on this URL www.islahulmuslimeen.org/test_mp/run_video.html.
Thank you so much for your kind and prompt reply. -
Click on this link...there is an extra dot.
http://www.islahulmuslimeen.org/test_mp/run_video.html -
Nope. I don't do flv just mp4 so I'm not sure what is wrong.Originally Posted by azam
[help] Jump to specific url after playing wmv video file
By techtonik in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2011, 06:23 -
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
Can someone recommend good low-mid-price system for video-editing/capturing
By johnharlin in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2011, 07:08 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
Best mid-range CPU for video (transcoding, HDTV, HD)?
By squegole in forum ComputerReplies: 7Last Post: 3rd Aug 2007, 14:29
