Hi,
I have several questions about AVidemux. I've figured out how to trim the base of some VHS tapes that I imported
to mpg. This changes the file from 720x576 to say 720x568. When I author the dvd using Nero it seems to take a long time to encoding whereas if I dont't trim it only takes minutes. Is there any way in Avidemux of trimming the file but expand the trimmed file back to 720x576 ? I noticed a sort of movement blur on one video. Someone told me I had to deinterlace the file there are 7 options: yadif, mcdeinterlace, deinterlace, kerneldeint, tdeint, libavcodec, decomb. I tried yadif, the quality was good but I got flashing that wasn't on the VHS tape. I know the solution to all these problems is a full frame TBC. I put a £10 bid on ebay for one, the winning bid was about £100. I am sure one of these things would have far more capability than I need. How come none of the authoring packages like Nero/Cyberlink DVD suite 7 have trim facilities. I would have thought this was a useful facility since I have this requirement currently. Any help appreciated.
K109
Try adding a black border.....that doesn't alter the actual size of the video.Originally Posted by Kalash109
"Someone" is usually wrong.Someone told me I had to deinterlace the file"
If this is for DVD -- NEVER DEINTERLACE!!!
If this is for web video, like Youtube, then deinterlace is needed, yes, a proper one. Most methods ARE NOT proper, especially not if it's just a checkbox.
Mask the entire overcan region in black. Yes, this re-encodes.
Interlacing and cropping/masking discussed here: http://www.digitalfaq.com/guides/video/capture-understand-sources.htmWant my help? Ask here! (not via PM!)
Yadif is probably the best of those but deinterlacing usually leads to jaggy artifacts. Some work better with some material but worse with others. You'll have to test them yourself with your video.Originally Posted by Kalash109
Interlaced video will still be interlaced after a TBC. The deinterlacer may work a little better with the cleaner source though.Originally Posted by Kalash109
As others have pointed out, there is no reason to deinterlace if you are making a DVD. All DVD players support interlaced encoding and either the DVD player or TV will deinterlace if necessary.
New Free MSU Deinterlacer
By diablo23q in forum Video ConversionReplies: 1Last Post: 22nd Feb 2012, 10:55 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 21:07 -
Best Vdub deinterlacer?
By brassplyer in forum RestorationReplies: 14Last Post: 25th Apr 2010, 22:50 -
Best deinterlacer
By Xpenguin17 in forum EditingReplies: 12Last Post: 14th Sep 2009, 11:40 -
MSU Deinterlacer Problems
By kernelhack in forum RestorationReplies: 3Last Post: 26th Sep 2008, 14:16
