Hi,
I have my family videos put on DVD so I have a set of VOB files in each DVD.
Can I
1/ copy those VOB files from DVD on my hard disk
2/ rename them to *.mpeg2
3/ and encode them to Divx *.avi with virtualDub ?
thanks
nalooti
Use instead AutoGK or Handbrake and convert directly from the dvd to avi divx (or copy the video_ts folder to your hdd and choose it as input).
If you prefer virtualdub then use vob2mpg on the dvd and then open the mpg in virtualdub(with the mpeg2 plugin) or virtualdubmpeg2. -
You wont even need to use vob2mpg if you use the fccHandler's MPEG-2 plugin, it will import all vobs in the order (eg, vts_01_01, vts_01_02, vts_01_03, etc) into virtualdub.Originally Posted by Baldrick
Question Regarding Size Change from VOB to AVI
By vipin in forum Video ConversionReplies: 1Last Post: 9th May 2010, 22:46 -
question on vob files
By rtr720 in forum Authoring (DVD)Replies: 12Last Post: 17th Jan 2010, 11:00 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
VOB question
By danielmak in forum MacReplies: 4Last Post: 5th Sep 2008, 20:02 -
VOB to AVI back to VOB
By fatla00 in forum Authoring (DVD)Replies: 23Last Post: 11th Oct 2007, 03:28
