My TV has 1080p HD DivX support (LG 32LH3000 with hack enabled)
it doesnt play DTS audio though but plays MKV files and AVI , DIVX , TS (no de-interlacing apparantly..??)
which converter/encoder is best to convert a MKV with DTS to another file that WILL play on my TV with BEST quality video?
at the moment I only have an 8Gb USB stick but plan to get a USB Hard Drive
thanks
Extract the video and audio with tsmuxer and use eac3to to convert the audio from dts to ac3,them install mkvtoolnix and use mkvmergegui to merge the extracted video and converted ac3 back to mkv.
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 16:44 -
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 18:38 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Whats an Rpex codec and where can I get it
By Bob2541 in forum Software PlayingReplies: 7Last Post: 22nd Feb 2010, 00:20 -
whats a good codec pack
By bmzxzx in forum Newbie / General discussionsReplies: 29Last Post: 7th Jun 2009, 19:58
