can anybody tell me why?
thx!
	This is a Video editing forum, not a poly editing forum.
 Autodesk what ? Max ? Maya ?
 Have you collapsed your object to a mesh ?
 I have not seen a lot of 3D related discussion here, so I suspect you need to find a dedicated 3D forum to get real support. I suggest http://www.maxforums.org/Read my blog here.
	hmm why i always found you anywhere?
 thanks i`ll trydon`t have a friend.....
  Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Jan 2011, 00:35
  Why does the video I edit in Cyberlink look darker after I edit it and postBy Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 06:08
  Virtualdub - Edit without re-encoding (except at edit point)By itsonlyme in forum EditingReplies: 2Last Post: 26th Feb 2010, 06:59
  Edit, add, extract WAVE and edit file tags with new Machete 3.5By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05
  need help in choosing a format after video edit (DV then edit then DVD)By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
