Ok i have a WMV HD
And i used SUPER to convert itFormat : Windows Media
File size : 7.90 GiB
Duration : 1h 49mn
Overall bit rate : 10.3 Mbps
Maximum Overall bit rate : 14.8 Mbps
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Description of the codec : Windows Media Video 9 Advanced Profile
Duration : 1h 49mn
Bit rate mode : Variable
Bit rate : 9 532 Kbps
Width : 1 920 pixels
Height : 820 pixels
Display aspect ratio : 2.35
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.253
Stream size : 7.26 GiB (92%)
Language : en-us
Audio
Format : WMA3
Format profile : M2
Codec ID : 162
Codec ID/Info : Windows Media Audio 3
Description of the codec : Windows Media Audio 10 Professional - 768 kbps, 48 kHz, 5.1 channel 24 bit 1-pass CBR
Duration : 1h 49mn
Bit rate mode : Constant
Bit rate : 768 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Stream size : 600 MiB (7%)
Language : en-us
But the AVI plays really fast, in Windows Media Player and in BS Player..? any ideas as to why also i don't hear any audio.Format : AVI
File size : 1 005 MiB
Duration : 1h 49mn
Overall bit rate : 1 287 Kbps
Director : created.with.SUPER(C).v2009.bld.36
Writing application : SUPER(C) - by eRightSoft
Video
Format : AVC
Format profile : Baseline@L1.3
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : H264
Duration : 1h 49mn
Bit rate : 1 020 Kbps
Width : 1 280 pixels
Height : 720 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.046
Stream size : 797 MiB (79%)
Writing library : SUPER(C) by eRightSoft
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 49mn
Bit rate : 256 Kbps
Channel positions : Front: L C R, Surround: L R, LFE
Stream size : 200 MiB (20%)
Alignment : Aligned on interleaves
Interleave, duration : 32 ms (0.77 video frame)
Interleave, preload duration : 512 ms
Closed Thread
SUPER sucks.
H264 in AVI is a bad idea, unless you use VirtualDub and ffdshow.
I recommend Avisynth's BassAudio and SoundOut plugins for converting WMA to AC3.
Didn't you already ask this? There are better choices than Super as was noted.
https://forum.videohelp.com/topic370031.html#1982908
Yep, ONE topic is enough! Continue in https://forum.videohelp.com/topic370031.html#1982908 .
Try handbrake also!
Curious problem. WMV to AVI no sound.
By sebblewich in forum Video ConversionReplies: 1Last Post: 3rd Jan 2011, 05:49 -
problem playing wmv files
By harryhansra in forum Software PlayingReplies: 2Last Post: 23rd Jun 2010, 05:42 -
Windows Media Encoder: AVI to WMV Two-pass problem
By apoon204 in forum Video ConversionReplies: 1Last Post: 24th Mar 2009, 03:45 -
Playing HD (.mkv) and XViD\DiVX (.avi, .wmv)
By yonyz in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 14:18 -
WMV playing problem
By Digiface in forum Software PlayingReplies: 7Last Post: 5th Feb 2008, 15:00
