I want to create flash-video (.flv files) for the web from Blender. Blender is a free 3D animation application that includes an excellent video editor. I'm very new to Blender, using v2.48a, on Windows XP. Following earlier research, I installed 'FFDShow tryouts', which solved some problems. Blender crashes when I try to output an FLV file from the VSE. I can output a very nice avi from Blender with the huffYUV video codec (lossless), or the xvid codec. I have Adobe Medio Encoder (AME), for converting video to flv format, but AME crashes when converting Blender created video to flv. Summary:
- Blender crashes when I try to output an FLV file from the vse.
- AME crashes when used to convert a Blender-h264-avi to flv (the avi works in windows media player),
- AME crashes when used to convert a Blender-xvid-avi to flv (the avi works in windows media player),
- Quicktime mov file from Blender has no video (it does have audio).
So I have been looking at ways to use FFMpeg to convert a Blender-avi to flv (i.e. remove AME from the process). I'm using WinFF (a GUI for ffmpeg on windows). With WinFF I get flv-video that is much too rough (probably too compressed). If I use WinFF to convert a Blender-avi to a DivX-avi, Then I use Adobe Medio Encoder (AME) to convert this to flv, I get better video but the audio is out of sync.
I feel like I've tried a lot, but I'm at a deadendCan anyone point me in the right direction to produce quality flv with synced audio, from Blender? I suspect the possible solutions could be in any of the following:
1. How to output FLV video from Blender without crashing?
2. How to update/fix video codecs in Blender so AME doesn't crash when converting from a Blender avi?
3. Settings for FFMpeg (using WinFF), to output less compressed flv, with synced audio.
1. Can you export to h264 mp4? THen use it as it is supported by flash.
2. Have you tried any other codecs than huffyuv and xvid?
3. Increase the bitrate, I think you can change it in WinFF.
Or convert the huffyuv avi to mp4 with h264 video and aac audio, it works fine in flash also. Use handbrake or xvid4psp. -
Thanks for the quick response Baldrick
ok, In Blender, I have an option to export as MPEG-4, but when I try Blender crashes. So I guess thats a 'No'.
However in WinFF I just did the following:
1.) Converted my Blender huffyuv-avi to MPEG-4 with the pre-set 'MP4 Fullscreen'.
1a.) Used Adobe Media Encoder to covert the new mp4 to FLV. Result: Good video but audio is out of sync.
1b.) Used WinFF to covert the new mp4 to FLV. Result: Rough video and good audio.
In Blender I only have the options: mpeg-1, mpeg-2, mpeg-4, DV. However Blender crashes with all of these!
The only other codecs I can see in Blender are huffyuv and divx. I don't know how to add codecs to Blender. I'm new to this, I get the feeling the issues in item 1 above are in the right direction.
In WinFF I have created my own modified preset, based on the settings of existing presets for FLV, this is what I have:
-vcodec flv -f flv -r 30 -s 480x360 -b 900kb -g 160 -cmp dct -subcmp dct -mbd 2 -flags +aic+cbp+mv0+mv4 -trellis 1 -ac 1 -ar 22050 -ab 56kb
Any idea what I should change in the above for either a much better bitrate or synced audio. (Its all a bit swedish to me).
Do you know what I should put into the WinFF preset to achieve this?
Blender Tutorials for the Video People
By tin2tin in forum Latest Video NewsReplies: 20Last Post: 10th Jan 2012, 15:20 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 14:53 -
Video Noob - how to create dvd for dvd player from avi, flv files..?
By acegap in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 08:10 -
What's the best FLV converter + best method to create FLV's from pure video
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 20:23 -
looking for program that create flv video for youtube from mp3,image,..
By method in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 04:56
