I downloaded a script from a user on this forum. It works well, but I want two things- I would like the resolution to stay at 1920x1200 (the native resolution of my Canon HF200) and I would like no normalization on the audio. I am very bad with manipulating avisynth scripts so does anyone know how to make this possible losslessly? Or is there another script that is better to use?
Code:@echo off del *.aac del *.h264 del *.avc del *.dga del *.ac3 del *.wav del *.avs del *.log cls for %%a in ("*.mts") do xport -h "%%a" 1 1 1 && ren bits0001.mpa "%%~na.ac3" && ren bits0001.mpv "%%~na.avc" for %%b in ("*.avc") do DGAVCIndex -i "%%b" -o "%%~nb.dga" -e for %%c in ("*.ac3") do azid "%%c" "%%~nc.wav" for %%a in ("*.wav") do normalize -l 0 --peak -v "%%a" for %%a in ("*.wav") do faac -b 192 "%%a" -o "%%~na.aac" for %%a in ("*.dga") do @echo loadplugin("dgavcdecode.dll") >> "%%~na.avs" for %%a in ("*.dga") do @echo load_stdcall_plugin("yadif.dll") >> "%%~na.avs" for %%a in ("*.dga") do @echo AVCSource("%%a") >> "%%~na.avs" for %%a in ("*.dga") do @echo yadif() >> "%%~na.avs" for %%a in ("*.dga") do @echo fadein(15).fadeout(15) >> "%%~na.avs" for %%a in ("*.dga") do @echo Lanczos4Resize(1280,720) >> "%%~na.avs" cls for %%a in ("*.avs") do x264.exe --qp 64 --bitrate 6000 --ref 10 --bframes 0 --b-pyramid --b-rdo --bime --weightb --subme 6 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --threads auto --thread-input --progress --no-psnr --no-ssim --output "%%~na.h264" "%%a" for %%a in ("*.h264") do mp4box -add "%%a" -add "%%~na.aac" -fps 29.97 -new "vimeo_%%~na.mp4" del *.aac del *.h264 del *.avc del *.dga del *.ac3 del *.wav del *.avs del *.log
Try remove the normalize and Lanczos4Resize lines from the script.
But this is not lossless, reconverting to h264 and aac will reduce the quality a bit. What is you goal to change to mp4 file? If just computer playback why not leave it as mts. -
Final Cut will not read MTS and the Apple codecs that convert it to a usable format are garbage. Is there a better lossless conversion process?Originally Posted by Baldrick
well you aren't going to get 1920x1200 from any program. the cam only records 1920x1080.
from canon
the Apple Intermediate Codec HDV 1080i60 should work fine for that cam's video.The Canon VIXIA HF200 not only captures images in Full HD, but records and outputs at 1920 x 1080
MTS to MP4 conversion without re-encoding
By steven2583 in forum Video ConversionReplies: 21Last Post: 4th Nov 2015, 10:56 -
Best way to Convert AVCHD (.MTS) >> H.264 SD (MP4)?
By ran007 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 59Last Post: 5th Nov 2011, 04:19 -
convert .flv to .mkv losslessly
By lovelove in forum Video ConversionReplies: 8Last Post: 19th Jul 2011, 04:04 -
Losslessly convert AAC file to MP3?
By sldvd in forum AudioReplies: 16Last Post: 17th Nov 2010, 07:04 -
combining MP4 and MTS files
By mikey111k in forum EditingReplies: 3Last Post: 2nd Nov 2010, 05:05
