I've successfully ripped the 2 sides of a "flipper" DVD. I'd like to join the 2 sides together as a single file. After this I would like to either burn it to a DVD+R DL disc, or to shrink it to a suitable size to burn to a single-layer DVD.
I know how to do everything except join the 2 sides to a single file. How do I do this?
[s:4f2a5ee196]DVD Rebuilder[/s:4f2a5ee196] DVDRemake Pro
One main menu goes to each sides main menu
Or
DVDShrink in reauthor mode but no menu -
You mean DVDRemake Pro, don't you stiltman? He shouldn't need to encode and DVD-RB doesn't join DVDs anyway.
DOH!Originally Posted by manono
Yes thank you for the correction. I did indeed mean DVDRemake Pro -
Do note that dual layer size is actually about 10% smaller than 2 times single layer size. If your 2 single sided discs are each close to filling up a single sided DVD, they'll be too big to fit on a dual layer disc. Just be aware that this could happen. You could also get lucky as each side might only be, say, 4 GB, which would easily fit when joined together.
Single Layer VS Double Layer, is one "better"?
By mjvgiese in forum MediaReplies: 4Last Post: 17th Feb 2010, 18:21 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
Is there such a thing as "DVD-RW 4X Double Layer 8.5G"???????
By will7370 in forum MediaReplies: 2Last Post: 3rd Jun 2009, 18:04 -
"splitting" dual layer to 2 dvd+r?
By tlinehan in forum MacReplies: 5Last Post: 13th Jul 2008, 17:42 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08
