I'm planning on moving my desktop to another room and I was deciding on what type of wireless adapter I should get: a USB or a PCI. Having no experience with wireless adapters I don't know what type would be better for my situation. The desktop will be moved two walls away from the router, which is about 20-25 feet. The PCI would have to be against the wall and the USB will be inserted to one of the front ports of the tower. Given the situation, what would be a better pick? USB or PCI?
The distance isn't very far at all. Hell, I can pick up two other (encrypted) networks besides mine, and no neighbor is closer than 50 yards away. I suspect either would work for you, if the walls are typical wood frame/drywall construction. I have one of each: PCI wireless card and USB dongle, both work fine with a Belkin router. (Yeah, I know, but it was cheap and it works).
Good luck.
Pull! Bang! Darn! -
I've had problems with several of the USB wireless LAN devices, lots of intermittent disconnects. There was a Linksys one that drove me crazy. I threw the thing out and vowed never to get another USB one.
"Quality is cool, but don't forget... Content is King!" -
I've got 2 of USB ones: Lynksis and SMC. I use primarily SMC, because the interface is much more clear and the connection is without any problem. Lynksis is getting on my nerves because of its messy interface.
If I had to make the choice, I would go again for USB one. It is more versatile (you can use a USB cable to get the adapter at the best position, or use it on laptops that don't have WiFi).
In addition, it doesn't use a PCI slot, leaving it free for something else (network card, sound card, TV tuner card, extra ports/interfaces cards, etc...). -
Do you already have a router? All routers aren't created equal and can affect connectivity also. I had both a Hawking and a D-Link router that had such poor range they were returned for refund. I've had very good performance with a US Robotics router and a Trendnet router. I read that PCI wireless adapters are more reliable than USB, and I've had no issues with my PCI adapter but have no experience with the USB adapter.
I've been testing 2 wireless N (150) usb adapters on 2 computers and they work well between 1 and 2 floors down from the router (wood, plaster drywall). I chose usb for the flexibility and not to tie up pci ports that are getting rarer in newer machines. If you haven't bought anything yet, get a wireless N (300) for best range and performance. I didn't need more range so my N (150) router and usb adapters work fine for me. If you have kids, controlling access to the net is as easy as pulling the usb adapter.
There's not much to do but then I can't do much anyway. -
USB dongles have the advantage that you can put them on a long cable and put them wherever they get the best signal.
You can also make an effective antenna out of scrap, to boost the signal if necessary.
See http://www.usbwifi.orconhosting.net.nz/
If your router already has wifi, borrow a laptop with wifi and check out the signal strength.
Alternatively, you can use a powerline ethernet adapter and run your signal through your electric cables.
Wireless N Adapter recommendation.
By Poppa_Meth in forum ComputerReplies: 13Last Post: 20th May 2011, 11:26 -
Wireless Router and Adapter Help/?'s
By Moontrash in forum ComputerReplies: 14Last Post: 20th Apr 2011, 12:55 -
What usb wireless N adapter to get?
By neworldman in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 09:49 -
Wireless usb adapter on WD TV
By kyrcy in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Apr 2010, 18:50 -
Wireless Adapter
By Sakuya in forum ComputerReplies: 13Last Post: 21st Dec 2009, 23:40
