I have two internal hard drives. One is like 70 GB and the other is like 100 GB. I reformatted my computer and deleted both partitions. Now there is only the 70GB, but the D: drive of 100 GB hard drive is no where to be found. What happened?
				Results 1 to 12 of 12
	Under VOLUME, I only see the 74GB HD (it is drive C/disk 0). Disc 1 is my 100 GB HD. It is "unallocated".
 I thought you are suppose to delete partitions whenver you want to reformat. I do not know why the 100GB is not showing up.
	Am I suppose to right click and go NEW PARTITION? "Primary partition" or "extended partition".....then it asks "partition size in MB" which is currently defaulted at 114471MB.....not sure about what this is.
 My minimum disk space is 8MB.
 My maximum disk space is 11447MB.
	It is saying unallocated because there is no partition on the drive in question. You must create a partition, format the partition and assign it a drive letter. Believing yourself to be secure only takes one cracker to dispel your belief.
	Choose Primary partition. I think,therefore i am a hamster.
	johns0, what is extended partition mean? I already have the 70GB HD set at drive C.
 What should I set the partition size to? What does this mean?
	you can have up to 4 primary partitions, or 3 primary partitions an 1 extended partition, an extended partiton can have several "logical drives"Originally Posted by jyeh74
 I usually send "My Documents" to another partition other than c:, that way I can completely trash my OS and my data is safe even if I haven't backed it up yet
 ocgw
 peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
 https://forum.videohelp.com/topic368691.html
	Set it to the maximum size allowed. I think,therefore i am a hamster.
  Do partitions on HDD slow down performance ?By Noahtuck in forum ComputerReplies: 20Last Post: 19th May 2014, 11:33
  HDD Partitions question.By SE14man in forum Newbie / General discussionsReplies: 13Last Post: 24th May 2011, 15:32
  FFMPEG -partitionsBy Klagar in forum Video ConversionReplies: 0Last Post: 4th Oct 2010, 12:12
  Best way to partion a 1TB into 2 partitions using Fat32By cal_tony in forum ComputerReplies: 6Last Post: 21st May 2009, 13:10
  Join two partitionsBy Jomapil in forum ComputerReplies: 5Last Post: 11th May 2009, 17:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
