I am new and need help.
I just purchased a Panasonic DVD/VCR combo machine that records.
The Panasonic DVD VCR Combo yields a pattern effect while recording, while both TV and Combo machine is set to channel 3.
I was told by Panasonic to set the TV to channel 4, and the machine to channel 3 when both playing and recording.
Once this is done, the pattern effect goes away.
Afterwards, when all is shut down, everything needs to be reset because you will then see and hear noisy snow on the TV screen.
It's confusing to switch back while not recording. It's also laborious and it takes the ease out of using the machine.
Please reply with suggestions to get around this and without making all the fussy changes? Is there a filter that can be installed before the coaxial cable
goes in and out of the machine.
Panasonic suggested to only use RCA cables. But the same pattern effect displays on the screen.
Would an "S" cable help?
				Results 1 to 1 of 1
  What is AVCHD recording, how will it effect me?By seven1970 in forum Video Streaming DownloadingReplies: 14Last Post: 19th Nov 2014, 08:51
  recording test pattern on a vcr from PCBy mammo1789 in forum Capturing and VCRReplies: 11Last Post: 13th Apr 2012, 10:59
  Strange shaking effect in recording while moving the videocameraBy anegroo in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2010, 10:25
  HELP: Looking for a GOOD DVD/VHS combo - Recording optionalBy UNOWEN in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Sep 2007, 12:38
  2 questions regarding Panasonic DRM16 machineBy MeekloBraca in forum DVD & Blu-ray RecordersReplies: 5Last Post: 15th Aug 2007, 09:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
