Does anyone have any experience converting video to FLV within Flash Professional ? What is the quality output ?
Results 1 to 15 of 15
Yes.
Quality is better than any rip-off FLV encoder, that's for sure.
The Adobe CS3 or CS4 converter works well.Want my help? Ask here! (not via PM!)
Oh well that saves me a lot of headache and money. I own flash professional I'll just use that to do my converting to FLV.
How can I export to FLV from Flash Professional, there is no option ? I've done some searching and I can't seem to find an answer.
Aren't you using the included video converter, flash video converter?
in cs3 it was called "flash video encoder". in cs4 it's just "media encoder"
flash professional is for creating websites. -
Adobe Flash Professional CS3. I can't find no "flash video converter" in CS3
Flash Video Encoder
Which CS3 do you have? I have the Master Collection.Want my help? Ask here! (not via PM!)
I have Flash CS3 Professional, not the master collection where should I look to find this ?
I searched the manual, and what I found does not describe anything in which you showed. Could you tell me how you got to the Flash Video Encoder ?
It's installed with everything else: Photoshop, Illustrator, InDesign, Premiere, Encore, Dreamweaver, etc.
Originally Posted by PowerFalcon
or check the c:/program files/adobe folder -
minidv2dvd - Thank you for pointing where it is directly, I was overlooking it this whole time.
What are the best professional tools from Source to FLV ?
By mrslurpee in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2009, 00:54 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Professional online encoding to flash format
By Ogilvy in forum Video ConversionReplies: 4Last Post: 17th Jan 2008, 18:45 -
Batch Converting of Varouous vide fromats to Flash flv with ffmpeg
By tempgp in forum ProgrammingReplies: 0Last Post: 7th Dec 2007, 15:58
