I suppose this is the correct forum as my ultimate goal is to burn a video to DVD. Any help is greatly appreciated.
I have an mkv of a tennis match in 720p that I would like to burn to a DVD for my dad. As the match is over 5 hours long (and I only have a single-layer DVD burner) my idea was to use any software to create a Dual-Layer Video DVD image and then use DVDFab to split it into two DVDs so as to lose the least amount of quality. My first attempt was to use DVDFlick, some free software I have had success with in the past. The process took about 12 hours from start to finish, but the video quality on the DVD was noticeably poor. Considering the original source is a gorgeous 720p video stream, I expected more from this process. The video quality is blocky and the animation a bit stuttered.
My next attempt was to use Adobe Encore CS4, as I figured it would have some better options for increasing the quality (such as triple-pass or another method). Unfortunately, I can't seem to import the mkv into Encore. I have tried updating my K-Lite Mega Codec Pack to 4.9.0 and even splitting the mkv into h264 (video) and ac3 (audio) files. The ac3 file imports just fine, but the h264 still gives me an error about not having the correct decoder. Lastly, I even tried importing the file into Adobe Encoder CS4 (as much as I hate adding another layer of transcoding) but that application wouldn't import the file either.
My ultimate questions are thus:Here is the codec information that MediaInfo generates from the file:
- 1.) Is there a good program for burning an mkv to a DVD (or at least creating an ISO to split across two DVDs) and maintaining as much quality as possible or...
2.) Is there a way to import mkv files into Adobe Encore CS4
Code:General Complete name : F:\Videos\Sports\Tennis\2008\Wimbledon 2008\Wimbledon.2008.Men's.Final.AC3.5.1.720p.x264-QXE.mkv Format : Matroska File size : 14.4 GiB Duration : 5h 32mn Overall bit rate : 6 187 Kbps Encoded date : UTC 2008-07-21 20:00:19 Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55 Writing library : libebml v0.7.7 + libmatroska v0.8.1Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 6 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 5h 32mn Bit rate : 5 680 Kbps Nominal bit rate : 5 800 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 25.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.247 Stream size : 13.2 GiB (92%) Writing library : x264 core 58 svn-736M Encoding settings : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5800 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.5:13.0 Language : EnglishCode:Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 5h 32mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 912 MiB (6%)
Thank you for such a quick response. Which utility will make selecting the start/stop time of the video (to keep with the 2 hours/DVD you mentioned) the easiest.
Will I be using HCENC as a separate utility, or do both of these utilities you mentioned just provide it as an encoder? -
Try using TheFilmMachine. This is all I use on all MKV's to DVD
I set it to best quality and use HCencoder which is included and
get a really high quality video. The program is free. I hope this
helps you.
How do I add permanent subtitles 720p MKV video
By Torresinho in forum SubtitleReplies: 1Last Post: 15th Sep 2011, 21:16 -
Comparison of 7 video converters: Converting a 720p mkv to 480p H.264
By srk in forum Video ConversionReplies: 2Last Post: 12th Oct 2010, 16:29 -
2 x 720p AVI with DTS - need 1 x 720p MKV with AC3
By snadge in forum Video ConversionReplies: 2Last Post: 25th Oct 2009, 13:38 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
MKV (720p) to DVD
By zork152 in forum Video ConversionReplies: 2Last Post: 13th Apr 2008, 15:59
