i followed all the instructions in that guide to ripping dvds and after i saved the project in dvd2avi i tried to load the .d2v file in TMPGEnc (the latest version) and it said that the video file wasnt supported..anyone know wht im doing wrong?
Yeah, I had the same problem. Don't use the new DVD2AVI, use the old version and it should load up just fine in TMPEGEnc.
It's not actually a fault with any newer version, it's all to do with the 'VFAPI' stuff being version specific.
This should clear things up for many people, here goes.....
When DVD2AVI is ran it puts the path of the VFAPI file into the registry, which is also where TMPGEnc looks:
[HKEY_CURRENT_USER\Software\VFPlugin]
"DVD2AVI"="C:\\Program Files\\DVD2AVI 1.82\\DVD2AVI.vfp"
Let's say I now do some FrameServing and make a 'D2V' file and run TMPGEnc e.t.c, all is fine.
Now let's say I run a different version of DVD2AVI, it will change this entry to the path of what I've just ran, example:
"DVD2AVI"="C:\\Program Files\\DVD2AVI 1.85\\DVD2AVI.vfp"
So if I now try to load the original 'D2V' file into TMPGEnc (from v1.82) it wont work as the registry entry is not pointing to the DVD2AVI.vfp of the DVD2AVI program I used to make the 'D2V' file.
So if you have multiple versions of DVD2AVI installed just make sure you run and shut down the version that made your 'D2V' file before using TMPGEnc.
Hope this clears a few things up.
CloneAD
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 19:13 -
Problems with Movie maker saving to dv-avi
By jbitakis in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 10:19 -
Odd problems with Avidemux 2.4, not saving it as .mp4....
By Kaminoshi in forum Video ConversionReplies: 9Last Post: 12th Jul 2008, 12:11 -
no DGIndex timestamp while saving project file
By ecc in forum DVD RippingReplies: 1Last Post: 22nd Dec 2007, 14:38 -
Many problems with editting video project.
By bluestar88 in forum EditingReplies: 0Last Post: 3rd Jun 2007, 18:47
