Hi everyone,
I'm trying to to convert couple of files to 3gp. I have a sample 3gp but I'm unable to match it's settings. According to Gspot codec for video is mp4v, audio AMR narrowband, container says 3gp4: 3GPP Media (.3GP) Release 4, Recommended Display Size: 176 x 144. File lenght is 1.59sec. and it's 1.26MB big. Everything I've tried I always get bigger file. Can someone please suggest how to match these settings? Thx a lot
With a source of identical length (1.59 sec), try matching the resolution (display size) and the bitrate. You should end up with similar results. For testing, you may also want to eliminate the audio.
Google is your Friend -
What software are you using to perform the conversion?
Without knowing that, one can offer only generalities, so here are some:
1) If you have the option of multiple-pass encoding, then use it. By performing the conversion in more than one pass, the encoder can best allocate the available bits to best effect (more bits for busy scenes, fewer bits for less dynamic frames).
2) If the source file is noisy, perform some filtering. Even a small amount of filtering can have a significant effect on bitrate/quality.
3) Make sure that, in your comparisons, you are looking at clips with the same resolution, framerate and bitrate.
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
How Can I Convert An MPEG-2 To AVI via command line to achive target size
By onesikgypo in forum Video ConversionReplies: 19Last Post: 22nd Jan 2010, 12:46 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
How to achive best MPEG2 file?
By arvin in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 18:12
