I will have to class myself as a newbie, coz it been while since i authored a dvd with menu.
Anyways i was wondering if anybody can help, I recently went to my school reunion year of 97, and recored it all.
Ive put it on the computer, that was no problem, but now is the tough bit for me.
Well I had a idea for the menu,, for the opening track I want to have Year in normal writing no problem, I no how to do that but, what i real want to do, if it is possible, to have the 97 in moving frames from the actuall video itself.
So the 97 looks like 97 but made up of small scenes from the actual video, like an ad i saw on tele, carnt remeber which one though.
Is there any software out there i can use, which is easy enough to use, for me to complete this task.
Thank You very much, any help or information on this, i will be very grateful.
Thank You.
Dal.
Is English your first language? If not, maybe you can get someone to translate for you. Try posting in your native language and maybe someone here can translate it for us so that we may help you.
From what I was able to decipher from your post, you can use Wax to achieve this effect(?), if I'm understanding your post correctly. -
dbanga, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And since what you seem to want to do falls under authoring, moving you to our Authoring (DVD) Forum. You can also look in our 'Tools' section for other programs that may help. Specifically https://www.videohelp.com/tools/sections/authoring-dvd There are also guides for these programs and other authoring guides available to the upper left on this page.
Where Does This Video Information Come From?
By hech54 in forum Software PlayingReplies: 5Last Post: 3rd Apr 2012, 11:51 -
Episode Information
By Deeman69 in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2012, 14:58 -
US Video CD information?
By phatrat1982 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2011, 22:07 -
h264 information?
By orangeboy70 in forum Newbie / General discussionsReplies: 0Last Post: 26th Mar 2011, 18:04 -
information on movies
By jason in forum Newbie / General discussionsReplies: 21Last Post: 30th Mar 2008, 20:24
