  1. Member videocheez's Avatar
    Jan 2003
    I haven't been doing to much of this video stuff in a couple of years and I forgot what I used to do. My buddy gave me a VIDEO_TS folder with some Michael Jackson dance moves and I wanted to burn it so that its a playable DVD. I remember that I had a freebie CD/DVD burning program that I simply burned as data file the VIDEO_TS folder and a blank AUDIO_TS folder and everything was fine. The version of Nero that I'm using recognizes that the contents of the VIDEO_TS folder has DVD files and says that if I burn it as a data disk in the manner that I described above, it may not be playable. How can burn this file and make a DVD playable in my standard DVD player? Any help or suggestions will be appreciated.
    Thanks in advance,
    VC
    This is so much fun!
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I have Nero 6, and I switch to Nero Express, then DVD-Video files, then add IFO, BUP and VOB files here.
    Dunno if it is different in later versions of Nero.
    If in doubt, Google it.
