I googled this error and found various topics discussing it, however, none of them had the problem continue regardless of what they were compiling. If I use dummy videos, no audio, or completely diff source files it still pops up pretty much right after I click start.
It will finish the little "generating cells" part but when it starts the actual compiling, the error pops up right away.
Ive been using Dvd Lab Pro 2 for over a year now and never had this problem. Dling the latest version didn't fix it. Could installing various codecs have messed it up? As that's the only thing I can think of.
Well i don't know if codecs would have any bearing on DLP, i'm pretty sure it would not.
You could always try the forum at the actual medichance website 8)
http://www.mediachance.com/forum.htm
http://mmbforums.com/ipb/ -
I have, also posted at afterdawn and cdfreaks. Media chance hasn't responded nor has afterdawn, but cdfreaks suggested the same thing, that i ask media chance.
So I thought i would try here as well. -
Ok here we go I had the same error with compile.aux and I tried everything on this site and some others like installing other DVD authoring software out there and nothing worked like dvd lab pro. To start out I am using Windows 7 X64 and out of a last effort I right clicked on the dvd lab pro shortcut on my desktop and went to compatibility tab I clicked on run this program in compatibility mode under Windows XP Service Pack 3 and then at the bottom clicked on run this program under Administrator and after I did that Bam it freaking worked like I never had a issue. I hope this helps one of you out there if your having the same dam problem and about to throw the dam computer out the window.
DVDLAB+Runtime Error+Compile.aux
By icemanatvcd in forum Authoring (DVD)Replies: 6Last Post: 27th Mar 2014, 07:08 -
DVD Lab Runtime error c++ compile.aux?
By dcook in forum Authoring (DVD)Replies: 10Last Post: 29th Aug 2010, 22:46 -
DVD Lab Pro Error
By SirEdward in forum Newbie / General discussionsReplies: 5Last Post: 4th Aug 2008, 17:22 -
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 19:39 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
