I had a laptop that I used in the classroom to show (among other things), some PowerPoint presentations. The laptop had an S-Video out and the TV has a S-Video in port. I got a new laptop and it only has a vga video port. I thought I read that there was a cable that went from vga to S-video, but only works if the vid card supports TV output. Well, I'm pretty sure mine does not. In fact the vid card is part of the motherboard. It's a Mobile Intel Series Express. What options do I have? BTW, the TV also has the 3 RCA plugs (red, yellow, and white) - I forget what that's called.
The laptop is a Dell Inspiron 1545 and I put Win XP Pro on it.
You'll need a VGA to s-video or composite scan converter. They start around US$50 and go up to several hundred dollars.
I checked today and in addition to S-video and the R,Y,&W RCA connectors there is a panel called component input. There are 5 RCA connectors: 2 red, 1 blue, 1 white, & 1 green. Could I use those somehow?
Does your laptop have a 7 or 8 pin DIN connector? Something like this:
If so, you may be able to get component video from there with a simple adapter cable from the laptop manufacturer. If not you will need a VGA to component scan converter to use the component video inputs on the TV. If you have an HDTV the picture will be significantly better than s-video or composite. With an SD TV it will be a little better than s-video. -
You need something like this:
http://sewelldirect.com/PC-to-TV-Converter.asp -
Some problems you might run into with the cheaper VGA to s-video/composite scan converters:
They often have limitations on the resolution of the VGA signal. Sometimes as low as 800x600 (the one MOVIEGEEK linked to handles up to 1024x768). You may not be able to run your laptop at it's native resolution when using the scan converter. More expensive converters allow for higher resolution and some have pan and scan modes where you can zoom into the VGA picture and pan around.
Inexpensive converters are often very noisy. You get random snow, or stripes of noise or light/dark bands that run up or down the screen.
How to capture cable box output to PC
By mickelsen in forum Capturing and VCRReplies: 7Last Post: 1st Jan 2012, 18:13 -
coaxial output to cable TV
By kula in forum Newbie / General discussionsReplies: 13Last Post: 22nd Sep 2010, 14:45 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 16:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 14:50
