Hey all,
Haven't been around in a while. Seems to be some exciting stuff going on with the world of Blu-ray backup.
Anyway, I just installed the Virtual Windows XP on my Win7rc machine. It has an LG GBC-H20L bdrom drive.
Windows 7 sees it fine and shows the disc name when I insert a BD, but the virtual xp environment sees the drive as a cd-rom and thus, I can't use anydvdhd to do backups inside this machine. My other XP machine is in pieces right now, so I'm SOL unless I can get this to work. Any ideas? Thanks in advance.
-C
I know for a fact that Anydvd, Dvdfab HD Decrypter and BD Rebuilder work under Win 7RC. Check out my computer details. Been using Win 7RC for about 2 months now. On a side note, sometimes when a program doesn't respond right, Win 7RC asks if you want to re-run program with XP settings.
DVDlab Pro: Text set as visible isn´t visible in the result
By Alex89 in forum Authoring (DVD)Replies: 14Last Post: 12th Aug 2010, 08:09 -
is it possible to create a virtual drive in RAM ?
By AlinaVastag84 in forum ComputerReplies: 18Last Post: 23rd May 2010, 12:53 -
make mkv remove virtual drive
By ShinjiIkari1990 in forum Authoring (Blu-ray)Replies: 1Last Post: 21st Jun 2009, 05:00 -
Use your gmail account for a virtual hard drive.
By freebird73717 in forum ComputerReplies: 4Last Post: 7th May 2009, 16:27 -
Video not visible in editing software/visible in Media Player
By kb1985 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2007, 19:21
