Hello there, My production partner and I have been working on an ongoing project for about 2 months now. He uses Final Cut for Mac and I am on Adobe Premiere Cs4 for PC. On his system we use a plugin of Joes filters to create a soft glow, slight dreamy look to the whole project. I have been trying to find the same or similar plugin for Adobe Premiere but I have not had much luck , Unfortunately Joe's Filters are made only for Final Cut. Can someone recomend a plugin or filter that will create a similar look. Any suggestions will be much appreciated.
Thanks,
Doz
Results 1 to 1 of 1
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Encore versus soft-subs and MKV
By pc1971 in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 06:07 -
Tiffen Soft F/X 3 Glass Filter - is it good?
By buratino in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2009, 15:00 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Know any Free Adobe Premiere filter sites?
By plainfaced in forum EditingReplies: 0Last Post: 30th Dec 2007, 07:42
