I have an IDX and SUB file, not sure what either are lol, all I know is my player requires SRT files, is it possible to convert them to a single SRT file?
I found a guide on Google that explains this process, but only using Subresync, which is part of Vobsub program, but I can not get this application to startup, it wont load at all (Subresync) so is there any other programs out there that can do this easily? just a simple convert.
DVDSubEdit will do a simple convert, but it'll need a lot of editing afterwards. It takes VOB, SUP or IFO input. SubtitleCreator will do an instant conversion from IDX/SUB to SUP. Otherwise you'll have to do an OCR and SubRip is better than SubResynch. But it's still not quite 'simple'.Originally Posted by kazz0817
No. It'll only make an SUP file from an IDX/SUB. And that SUP file can then be used in DVDSubEdit to convert to SRT very quickly. But the conversion has lots of problems and will need heavy editing afterwards if you're at all particular about the quality of the subs.
The best way to get an SRT from IDX/SUB is with SubRip. But if you didn't like SubResync, you won't like SubRip either.
Conversion help.
By yugub in forum Video ConversionReplies: 9Last Post: 18th May 2011, 20:45 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
2.35:1 conversion to 1.85:1 (or 1.77:1)
By mgarrido in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2007, 23:21 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 10:46
