Hi
I have a problem i try to solve for hours and hours... and no solution![]()
I cannot open a .ts MPEG4 H.264 file - recording capped from HD channel from DVB-S2
I know you have to have a DirectShow Input plugin in VD>
I also read that i must have Haali Splitter
BUT EVERY TIME I TRY TO OPEN THE FILE I HAVE THE ERROR MESSAGE :
Code:Unable to set filename on media detector : hr:80004005
or
Code:Unable to create source filter : hr:80004005
I tried installing everything - K-Lite codecs, AC3 Filter, Haali Splitter, ffdshow, CoreAVC - AND NOT WORKING !
Its weird as before I reinstalled Windows IT WORKED somehow....simply the file opened and I could encode it easily to any format...
Please help me what to do !!! Im so tired of trying to get it work![]()
It's possible that your file is damaged
If you use avisynth to frameserve, it will be more reliable.
Install avisynth, open a text file in notepad in the same directory as your video, type the following, and rename the extension to .avs from .txt (change the filename to match)
DirectShowSource("video.ts")
Then open that .avs file in vdub -
Can play .ts files in DirectShow based players (WMP for example)?
When install Haali Media Splitter, set support for MPEG-TS?
Can try with other source filter - latest Gabest MPEG Splitter.
Other... can use DGAVCIndex/DGAVCDec and Avisynth script.VideoAudio.pl - Serwis o technologii wideo & audio
Adobe Premiere - MainConcept's H.264 vs x264 open source encoder
By rallymax in forum EditingReplies: 159Last Post: 19th Jun 2012, 20:51 -
Open h.264 in VirtualDub
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 6th Nov 2011, 21:21 -
edit FLV .264 in virtualdub
By mathmax in forum Video ConversionReplies: 4Last Post: 20th Apr 2011, 13:35 -
Which program to use for converting VOB to H.264 MPEG4
By user123456 in forum DVD RippingReplies: 1Last Post: 24th May 2009, 03:20 -
Mpeg4 AVC H.264 viewer for iPhoto/Quicktime
By rajupatel in forum ffmpegX general discussionReplies: 2Last Post: 30th May 2008, 17:14
