  1. Anonymous5494
    Guest
    Apr 2004
    Miskatonic U
    Interesting video - doesn't help at all, but nice try.
    A couple of things to try
    1. Even Pan and Crop doesn't work on very short clips. Not sure what the lower limit is, but if your clip is very short (and see it all in the video - no timeline shown) then try making it longer, then using EPC
    2. Check the tabs in the main area and make sure you haven't accidentally dragged the EPC window and docked it somewhere
    3. You might have accidentally dragged the EPC window off screen, in which case changing your screen resolution down to 800 x 600 and see if it brings it back into frame
    Read my blog here.
  3. Anonymous5494
    Guest
