Hi,
I like to join clips together of my son's sports games and put them up on youtube. I typically join 9-11 clips together lasting 7-9 minutes. I've noticed that I sometimes get one of the two following problems:
1. Sometimes the beginning part of a clip is missing (e.g. 2-4 seconds). Usually the clip in question is either short in duration (e.g. 10 seconds long or less) or the clip preceeding it is short; or
2. Sometimes the resulting joined clip contains all the video, but the audio will get sidetracked at some point (usually at the same point where, if I use a different program, the video is missing the beginning footage.). Usually the audio will be off by a split second. Just enough to be noticeable.
I've tried different joining programs and keep getting similar results (either the audio is off midway in the clip or the clip is missing some of the video). I've used Boilsoft Video Joiner, Ultra Video Joiner, Video Edit Master and others.
Here are my questions:
1. Is missing footage/audio track off by a split second a common problem when joining clips?
2. Could it be my PC?
Is something that just happens and there's nothing that can be done? Thanks for any advice out there.
Thanks for the reply. I film the video using a Sony Hard Disk Drive camcorder. The source material is indeed in .mpg format. I'll try your suggestion to convert the clips to AVI first. Is this what everyone does? I have an older PC - is that possibly the source of the problem as well?
Thanks.
Feature Film Lost footage on DVD
By colossus34 in forum Video ConversionReplies: 20Last Post: 4th May 2011, 14:53 -
convert XviD to DVD format but lost audio track 2
By zenghe in forum Video ConversionReplies: 2Last Post: 3rd Mar 2009, 17:34 -
Lost Camcorder Footage
By newbe tech in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2008, 16:50 -
How to add different video clips on the same audio track ?
By AAC in forum EditingReplies: 5Last Post: 21st May 2008, 19:36 -
FLV clips without an audio track from YouTube crash Quicktime
By panhype in forum MacReplies: 2Last Post: 9th Jan 2008, 13:11
