I was having no problems with BD Rebuilder. I had made backups of all three X-Men and Pirates. Then I went to make backups of a few more and now all I am getting is encoding failures. I have tried going to a newer version and have also tried older versions, all with the same results. I don't know what happened. Anyone else having these problems? I am trying to shrink these down to fit on a 25GB disc. I didn't change any settings, so I am at a loss for whats going on.
Results 1 to 30 of 31
i am also having problems tring to fit some new titles onto a 25g disc has any got any solutions
have you tried the new fab dvd 6.2.20 for taken and casino royal
Taken and Curious Case of Benjamin Button, use movie only back-up. And on Taken make sure you have eng subtitles selected and uncheck the keep only one subtitle for each language box. Otherwise towards the end of the movie you will not know what the foreign people are saying, unless you are fimiliar with the language they are speaking.
haven't tried casino royale, but taken worked for me on whichever the current version of AnyDVD it was at the time.Originally Posted by davebarnes2009
Also are you using the free versions of AnyDVD HD and DvdFab HD Decrypter or the paid versions?
I'm using the paid versions, so that may or may not make a difference. -
I'm trying to make full movie backups of all these. Will fab dvd 6.2.20 do that?
i have just backed up benjamin button to a 50g disc with fab 6.0.2.2 it decrypts at the same time but will not shrink to 25g yet. dont have any dvd running at the same time
It lookks like bd rebuilder is the only tool that will do it? I will try to keep tweeking the settings to get these others to compress.
does anyone know of another program like BD Rebuilder or is that it? I just had Batman Begins fail on me. It said the x264.exe had stopped working.
Clown BD doesn't encode, just rip, remux and write imageOriginally Posted by mrswla
you know you can just drop any version of x264 encoder you want into BD Rebuilder right?
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
I don't understand what x264 encoder does. All I want to do is run BD Rebuilder and have it work. Do I download it and it automatically gets chosen by BD Rebuilder?
x264 is one of the tools that is downloaded when you download BD Rebuilder. But you can also download the latest release of x264 and replace the one that was downloaded with BD Rebuilder. Download x264 then open the BD Rebuilder folder. You will see a tools folder, open it. Then drag your new downloaded x264 file into the tools folder. Windows will ask you if you want to copy and replace your new file over your old file. Click on the yes button. Now BD Rebuilder will use the lastest version of x264.
I'll give that a try. Thanks! One other question. It doesn't fit the theme but I dont want to open a new thread. Do you know why Quantum of Solace will not even play on my PC BR Player? It doesn't even recognize it. I looked for a firmware version upgrade and it says it is up to date.
Not really sure why Quantum of Solace is not recognized. What is your bd drive and software player? I had no problem backing up my disc.
There are a lot of poorly manufactured discs that will have you pulling your hair out trying to figure what is wrong w/ your PC when it is just the discOriginally Posted by pandemonium
I couldn't rip Quantom of Solace till I realized there was a hair line crack on the edge that was almost impossible to see, I have been told this is common w/ the batches of certain titles
ocgw
This is really pissing me off. I can't get Taken or Casino Royale to compress (full or movie only) no matter ehat I do. Does anyone know of another program like BD REbuilder or is it the only one?
have you tried blu-ray to dvd 11 pro it only does the main movie i have used it several times with successbut i have not used it on those movies you will also need any dvd running
Thanks for the tip, nut I want to go from blue ray to blue ray (BD25). I want to keep most of the quality.
I just tried Rise of the Lycans and it failed almost immediately! I am lost. I didn't change anything and all of a sudden nothing will backup!! @%$@#!
Looks like Taken worken (movie only) with v. 0.24.02! Lets try the other ones....
i did manage to fit rise of the lycans full movie on to a 25g disc not sure which
version of bd rebuilder it was it may have been about 4-8 weeks ago when it was first released in the uk on disc -
Hi.. My problem with BD-Rebuilder is Result are Out Of Synch.. SUCKER PUNCH, ARTIFICIAL INTELLIGENCE, FIGHT CLUB, PLATOON, THE THIN RED LINE, STAR WARS TRILOGY (first and second) are the titles so far.. Very annoying actually.. After waiting for long time result is full dissapointment.. Any of you people having this sort of problem..? Any help will be appreciated.. Thank You..
@ se7ennio:
1) Have you ever successfully re-encoded a Blu-Ray with BDRB? If not, your configuration is probably wrong. Run inspect.exe from the BDRB folder and post the report here.
2) Dunno about most of those movies, but at least 2 have newish copy protection and complex java menus (Star Wars). You may want to be sure your decrypter is up to date and try again. I got the Star Wars Blu-Rays on the day of release and DVDFab couldn't rip a clean copy that BDRB could re-encode correctly. So I ran DVDFabPasskey in the background and extracted main movie with Clown_BD, which works fine. Then I ran them through BDRB, no problem.Pull! Bang! Darn! -
Yes, i did re-encoded so manytitles already.. Only those which i wrote befoe wasn't successful.. I'm also using DVDFab instead.. From this day on i'll try new version of BD-Rebuilder.. I'll give you the result asap.. Thanks anyway.
BD Rebuilder Movie Only Problems!
By kings322 in forum Blu-ray RippingReplies: 18Last Post: 1st Jun 2010, 05:11 -
BD Rebuilder problems.
By kings322 in forum Blu-ray RippingReplies: 2Last Post: 19th May 2010, 21:20 -
BD-Rebuilder problems
By Squeez in forum Blu-ray RippingReplies: 2Last Post: 4th May 2010, 17:15 -
problems with BD rebuilder
By rayray1 in forum Blu-ray RippingReplies: 3Last Post: 10th Aug 2009, 17:13 -
BD Rebuilder Problems
By ronorkis in forum Blu-ray RippingReplies: 3Last Post: 18th Jul 2009, 13:32
