Hi bros,
I'm using MediaCoder (http%3A%2F%2Fwww.mediacoderhq.com%2Findex.htm) to convert video file with the default settings:
How can I set up "Picture" to get the result like the capture below:
(with black letter box to add subtitles separated from pictures)
And, what soft can be used for batch converts with the same feature above?
I successfully converted with Virtualdub but it not support batch converts with default preset and different video format.
Is it possibly to configure Virtualdub to work with default preset?
Thanks.
Although I don't know the answer for batch converting, in the pics you've posted the AR seems off (vertically stretched). Also on a normal TV the subs will be cut off to a certain extent.
This is about how it should look:
If you want to keep the same frame size adding a few pixels of black to the bottom should fix both issues.
I've watched many Japanese Samurai movies (4:3 VHS) that were formatted to show the subs on the bottom bar. The bottom bar was as thick as the original top and bottom bars combined.
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 16:26 -
Can I crop and resize video?
By maldb in forum EditingReplies: 6Last Post: 13th Jun 2009, 20:06 -
Remove Letter Box
By Chala in forum Software PlayingReplies: 11Last Post: 21st Apr 2009, 22:52 -
Video Crop and resize
By quxote in forum EditingReplies: 4Last Post: 27th Feb 2009, 12:48 -
Crop, then resize to 240x320?
By miamicanes in forum EditingReplies: 2Last Post: 30th Dec 2008, 00:56
