I created a vcd from a bin/cue file that I downloaded from the net. The quality is good when I play the mpeg on my computer. It's about dvd quality. But when I burn it to vcd and play it on my TV it looks pretty distorted in some places. Is there anyway to have the same quality? Or is this just because the TV screen is bigger then the comp.
How good it looks on your TV will also depend on your particular hardware player and TV. Some better players can do some filtering of the video so that it looks better. However, if you have a gargantuan TV, the quality will suffer.
You've done nothing wrong in buring your CUE/BIN image and there is in reality nothing more you can do to improve the quality (except perhaps making your own VCDs from DVD rips or making XVCDs or SVCDs).
Regards.Michael Tam
w: Morsels of Evidence -
Is the VCD in the same format as your TV (NTSC or PAL)? Does your DVD player have a problem with CD-R or CD-RW? It could be a simple compatibility issue.
A VCD file looks great when played on a computer at the size of a postage stamp! Blow it up to fill a 32" TV, it no longer looks so good. Why? Because you can now actually see all the blocks and artifacts that are so tiny on a small PC monitor you cannot see them. Blow a VCD up to 60" and it looks pretty bad...
HD multistream creation
By remainz in forum Newbie / General discussionsReplies: 5Last Post: 14th Mar 2011, 10:12 -
5.1 AAC Creation
By doomgaze3 in forum AudioReplies: 8Last Post: 17th Mar 2009, 11:31 -
help with dvd re-creation
By souleye in forum Authoring (DVD)Replies: 0Last Post: 21st Jan 2008, 19:12 -
DVD creation..
By Fathead31 in forum Newbie / General discussionsReplies: 7Last Post: 5th Dec 2007, 23:46 -
Simple VCD/SCD creation with freeware.
By bigstusexy in forum Authoring (VCD/SVCD)Replies: 11Last Post: 3rd Dec 2007, 23:24
