  1. Member Lippy Lipstick's Avatar
    Mar 2008
    Between the tulips
    Okay, here's the problem:
    I often record things on my dvd-recorder. The recorder automatically
    makes a menu which shows up if you insert the DVD into any player.
    Question: What's the easiest way to get rid of this menu and make
    the DVD-content to autostart WITHOUT showing this menu?
    The DVD-recorder does not give me the option (it's an LG RH387H),
    and I don't want to re-render it just to get rid of this menu.
    Would IfoEdit give me the option to make my DVD to 'autostart'?
    Any suggestion willl be greatly appreciated.
  2. Member Lippy Lipstick's Avatar
    Mar 2008
    Between the tulips
    Thanks for the tip, almighty Baldrick. Will give PGCEdit a try...
  3. I'm a Super Moderator johns0's Avatar
    canada
    You can also rip the dvdrw with dvdshrink and reauthor at the same time,gets rid of the menu.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Or you could rip the disc with dvddecrypter in movie only mode.
    One tool one step.
  5. Member Lippy Lipstick's Avatar
    Mar 2008
    Between the tulips
    Never thought of using dvdshrink or dvddecrypter to do the job. After all, the first action is copying the whole bunch to harddisk. Thank you all!
