I have just installed the above mentioned M/B and am getting no response from the USB ports. I have 2 USB 2.0 thumb drives attached however they are none operational. Would really appreciate help from any member using the same board who can explain what is causing the problem.
Did you install the mobo drivers?Originally Posted by blinky88Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
That is a old model motherboard.
Did you check the BIOS to see if they are enabled? They may just be bad. Check Device manager to see if windows thinks they are working.
Suggestion: Buy a cheap USB2 pci card. -
Hi edDV,
Thanks for suggestion, never crossed my mind .... solved the problem. -
There should be divers for everything else too ... sound, ports, processor, display chipset, ...Originally Posted by blinky88Recommends: Kiva.org - Loans that change lives.
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 16:54 -
Asus M2A-VM Motherboard-opinions?
By bigshotceo in forum Media Center PC / MediaCentersReplies: 19Last Post: 25th Mar 2008, 18:27 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23 -
USB ports or motherboard or both??
By tryintoo in forum ComputerReplies: 21Last Post: 10th Jun 2007, 13:15 -
recommendations for motherboard ASUS or MSI?, dual amd 64 ?
By poolenglish in forum ComputerReplies: 3Last Post: 8th Jun 2007, 17:05
