Hi all,
i want to encode subtitle into MP4 video file from command line program, without changing video and audio. I used mencoder.exe, but I can not set the appropriate command line options and output file is always done with changed resolution. Can anyone help me with settings or suggest another command line program ?
Thank You.
It's not possible to burn-in subtitles without re-encoding - and every re-encoding causes quality loss, so you can't do it without some change in the quality.
If cameras add ten pounds, why would people want to eat them? -
So you are okey with reencoding? or else it's not possible.
Just set the resolution to the same size as the source?
[mencoder] No audio in last few seconds after encoding?
By MacDada in forum Video ConversionReplies: 0Last Post: 27th May 2011, 12:03 -
Re-encoding MP4 to change codec
By Joolz2020 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jan 2011, 22:58 -
Change Aspect Ratio of .mp4 without re-encoding
By rtharagan in forum Video ConversionReplies: 9Last Post: 27th Jan 2010, 11:07 -
Converting to H264 [.MP4] (mencoder) results in video playing too fast
By ChrisMtl in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2008, 17:02 -
MP4 (or any video) to FLV conversion using mencoder
By fireserphant in forum Video ConversionReplies: 10Last Post: 11th Jun 2007, 11:16
