Hi fellas,
I imported a bunch of pre-existing footage that's in 4:3 format. I'd like to be able to export this with the same 4:3 aspect ratio. When I export to QT, and open it, the video is 4:3, but the player is setup for 16:9. I've never done 4:3 before. Is there some kind of setting I need to change on the timeline? If so, what would that be?
Thanks in advance!
Jeff
THe Quicktime Player takes it's sizing from the aspect ratio
of your exported video from Final Cut. IF it is sizing to 16:9,
its because the exported video was flagged to be 16:9
(letterboxing your 4:3 video to make it appear 16:9).
The setting is preset in your Final Cut Preferences,
before you create a New Project / Sequence.
Open Final Cut, create new Project, Under Preferences, General Tab,
select the format of the Sequence to be used, either 16:9 or 4;3."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Uh oh.. what if I already created the project? Any way to change it now? Just asking because I'm not at home with my Mac to try this yet.
Thanks. -
You'd have to create a new Project, and move/reimport the media
and re-create the project from scratch( sure way) or you
could try to export it again from FCP as Quicktime to an Anamorphic
codec setting ( like DV NTSC 48khz Anamorphic) ( not entirely sure way)
and see if that fixes it...."Everyone has to learn, so that they can one day teach."
Urban Mac User
FAST RENDERING of Final Cut Studio Pro and After Effects files.
By Kevin Whelan in forum MacReplies: 3Last Post: 24th Aug 2011, 11:40 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 10:36 -
final cut expess HD rendering... why so slow?
By ednarophati in forum EditingReplies: 0Last Post: 18th May 2007, 15:22
