Hello
Im taking a movie and cutting him about 1 minute in order to put subtitles initially and later I want to join him then I am cutting it at virtualdub as direct stream copy
than past the subtitles , saving as - full processing mode
than im doing conversation so it won't get too much mb at the compression.
and than i want to join it so i define at the conversation app
the same video codec, video size. framerate,
and of course the same audio codec , audio bitrate , sample rate. audio channel
same as the original file.
and in some reason it wont let me join the files and every time yells : the video files have diffrent date formats
y it's happening and how do i solve it?
10x always![]()
Results 1 to 13 of 13
nice program! thank you
but as i see there is still problem.
when i dragged the 2 avi files into the avidemux, and clicked yes in the asking windows
about the automatic coding the frames, audio and stuff.
and in the and clicked file - save
the video is jumping somehow and not playing it correct
why is that? -
Because Avidemux is garbage, full of various bugs.
I suggest you try again with VirtualDub. I never heard of "different date formats," are you sure that's what it was? -
that's what it was
but not in virtualdub
in - fast AVI MPEG Joiner
in virtualdub i can't make it
dunno y -
Wait, you say you editted your clip with Virtualdub and then saved to a new file using full processing mode -- with which codec?
What compression was it before you converted to Huffy AVI?
With the newer Virtualdub, you can use Smart Render so as to not have to re-encode the whole clip. You don't have to save as clips. You can now exact frame edit (edit out exactly where you want instead of at key frames) and Smart Render instead of saving each segment and joining afterwards.
Oh, and AviDemux is not garbage. It will join a lot of clips that Virtualdub refuses to and does a few things that Virtualdub will not. That said, Virtualdub is my editor of choice but I do use AviDemux for certain tasks. -
the compression it was before is Xvid Mpeg 4 codec
and which version is the newest of virtualdub?
10x -
1.8.8/1.9.2 experimental (May 08, 2009) is the latest version of Virtualdub.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Then using Smart Render with the XviD codec set at unrestricted and a target quantizer of 2.00 is your best option. Just cut out the parts that you don't want and Smart Render the video and Direct Stream Copy the audio.Originally Posted by eliqush
I'm using Virtualdub 1.9.2 (build 31953/release)
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 02:53 -
Joining 2 video files- too complex for Virtualdub?
By miketheratguy in forum Video ConversionReplies: 23Last Post: 16th Aug 2010, 16:32 -
Error In Virtualdub Joining Two Like DV Files. Help?
By kpoman in forum EditingReplies: 2Last Post: 7th Jan 2009, 11:34 -
joining 2 AVI files via VirtualDub or another program
By cfs6254 in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2008, 12:15 -
Joining avi files with Virtualdub
By JaredKnight in forum EditingReplies: 10Last Post: 8th Jul 2007, 20:45
