How do I put sound on the menu that only plays while the menu is displayed and not over the top of the movie? When I click play the in Studio it shows the menu and plays the sound but when the movie part plays the sound of the menu is still heard instead of the movie sound.
Thansk,
J.![]()
Great GUIDE. Not. Moving you to our dvd authoring section.
You can put the song (mp3, wav) inside the sound track under the manu segment. You can either
pull the manu boarder longer to the same length of the sound file or cut the sound file shorter
to the same length of the manu. Cut the sound file is the same as cut the movie part. -
Extended the menu to the length of the song otherwise the song will repeat too early hich sounds terrible. The only way to confirm this was to create the DVD RW and it was ok so copied it to a DVD R
Please explain - I don't understand what you mean!Originally Posted by xxiangg
Pinnacle Studio - 2 Menu's.
By Apple 3.14 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2011, 18:34 -
DVD Menu bug in Pinnacle Studio 11
By P_Cherry in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2010, 09:22 -
Pinnacle Studio - Multilevel DVD Menu
By donpedro in forum User guidesReplies: 6Last Post: 5th Sep 2010, 09:16 -
Lost sound on Pinnacle Studio 10 on PC.
By Balliol in forum AudioReplies: 0Last Post: 17th Jul 2007, 19:25 -
Pinnacle STudio 10.5 Menu
By Chris Lewis in forum EditingReplies: 0Last Post: 12th May 2007, 12:55
