I have an mp4 file I am trying to convert to DV so I can edit it in Final Cut. I have a mac and I can play the file in VLC but quicktime wont open it. Usually I can use quicktime to convert MP4 to DV but its not working this time.
What program for mac will open anything like VLC and also convert to DV?
Here is a 1.7 meg sample
Thank you very much
20090303144511.mp4
Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together.
I could play a moment of it in VLC but everything else (QT Player, MPEG Streamclip) report the file is corrupted.
it's not an "MP4", it's a BluRay file (HD, Profile4.0, …) wrapped in "mpeg-Transport-Stream".Originally Posted by sneaux
Its wrapper and its contents are not compatible with QuickTime (and its wrapper is compatible with MPegStreamClip but not its contents).
For free, you could use Handbrake (and after, convert the resulting transcoded file to DV)
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
Herve said: "For free, you could use Handbrake (and after, convert the resulting transcoded file to DV)"
That worked for the sample you provided, sneaux. I used MPEG Streamclip for the DV conversion.
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 19:46 -
trouble with audio after appending a .jpg turned .mp4 to another .mp4
By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 09:55 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 04:53 -
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 20:24 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 21:24
