Alright, i have DVD Architect 5.0 and i have about 6 Xvid format AVI files and I want to burn the to a DVD, and for some reason when import them they don't have sound. I use ffdshow Rev3013 for codecs, and i've tried editing settings and it wont work, I cannot get sound to work in DVDA. Sound works fine in Media Player Classic thought. any help? thoughts? or ideas? any would be greatly appreciated.![]()
Results 1 to 9 of 9
welcome to the forum.
dvd architect is an authoring program only. is your intent to create a dvd that plays in a standalone dvd player? if so you must first convert the xvids to dvd spec mpeg-2 and ac3/wav/or mp2 audio. -
so there is no way for me to get them to directly import into DVD architect? i got Divx to work fine. alright, guess ill just convert em. thanks though!
converting videos to dvd spec is an encoder's job. try mediacoder, avidemux, vlc, thefilmmachine, etc.... there are bunches in the tools section.
or sony vegas if you have that to go with sony architect. -
DVD Architect will encode non-compliant material, however it's settings are far more restricted, and therefore the quality generally lower, than using a dedicated encoder or even Vegas. Vegas also does not like Xvid/Divx very much.
You are better off using AVStoDVD to output elementary streams that are DVD compliant, then using DVD Architect to author them into a DVD. You will get far better quality this way.Read my blog here.
You can use AVStoDVD to encode and author your disc, complete with menus, or have it encode to elementary streams so you can author with DVD Architect. It depends on what your authoring needs are.
Read my blog here.
DVD Architect Studio 5.0 plays my files at double speed and no sound
By MCnDaHouse in forum Authoring (Blu-ray)Replies: 2Last Post: 3rd Feb 2012, 11:22 -
DVD Architect 5.0
By Mr. Robinson in forum Authoring (DVD)Replies: 1Last Post: 4th Nov 2009, 11:59 -
samsung dvd-p171: bad sound with xvid?
By pengocha in forum DVD & Blu-ray PlayersReplies: 11Last Post: 10th Sep 2008, 14:09 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35 -
DVD Architect help
By monks19 in forum Authoring (DVD)Replies: 11Last Post: 23rd Aug 2007, 07:46
