I wanna make a copy of one of my DVDs, but whatever programs I use, it always says "circle redundancy check."
So my question is does anyone know any good soft I could try to record the DVD while playing it on my pc?
Any help would be very useful, thanks!
	Usually crc errors mean the dvd is damaged. There have been a few dvds that gave me problems and sometimes trying a different drive may help. When it comes to programs DvdFab HD Decrypter set to skip errors has worked the best for me though it usually takes a long time.
	Try ISO Puzzle to read the disc. Want my help? Ask here! (not via PM!)
	Both are really good softs, even though I have to exit at the middle cause it takes so long  , thanks for your two suggests! , thanks for your two suggests!
  Any software/hardware that can record TV in different quality?By dreamweaver888 in forum Newbie / General discussionsReplies: 14Last Post: 20th Jan 2011, 15:18
  Desktop record software?By neworldman in forum ComputerReplies: 1Last Post: 21st Sep 2010, 02:40
  Software to record phone callBy bambam in forum AudioReplies: 5Last Post: 2nd Mar 2010, 01:16
  Best Software to record for broadcast?By dreslick in forum Newbie / General discussionsReplies: 17Last Post: 30th Sep 2009, 13:26
  Music Cd Burning Software - Record 3 cd's at the same timeBy mn072065 in forum AudioReplies: 10Last Post: 5th Jun 2009, 10:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
