    Jun 2007
    I have a .mpg video file (mpeg-1 muxed) and .srt subtitle file. Both are named the same (except for the extension).
    In QT Player no subtitles show when viewing the video. Under View>Subtitles, "Off" is grayed out.
    Perian web site says it supports mpeg-1 and srt, but it's not working.
    How do I get these subtitles to show?
    PowerBook G3 / 10.4.11 / Perian 1.1.3
    Thanks.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Perian subtitling doesn't work on mpeg files.
    Haven't tried it but I wonder if VLC might support this?
    Jun 2007
    How can I view this video with subs (.srt)?
    Thanks.
    Jun 2007
    VLC 0.9.9a (the current version for PPC processors) crashes when avi video is played.
    Thanks.
  6. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    VLC 0.9.9a PPC supports this on my test mpeg-1 file.
  7. Member terryj's Avatar
    N35°25.24068, W097°34.204
    davecc,
    is it an .avi or .mpg file you are wanting help with?
    Have you tried demuxing the mpeg-1 through MpegStreamclip,
    and then try rebuilding a suitable file in Quicktime Pro?
    MpegStreamclip should demux the file fine,
    and then you can basically rebuild the file
    in Quicktime Pro, embedding the subtitles,
    ( or at least a link to the subs in the same folder
    as the demuxed files) and then you'll have a playable file.....
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
