    Apr 2003
    Hey guys!
    After a bit of advise please!
    My girlfriends rabbit has chewed through the cable of her Wii Sensor Bar, I had a look on amazon and ebay for a new one and there were so many I did not have a clue which to get! Have any of you had to replace yours and which would you advise to buy?
    The Nintendo one is apparently the worst one. Many of the 3rd-party ones are great. I would stick to a brand that is also found in the stores, not the Hong Kong no-names that are seen.
    The OEM one we have has major issues sometimes, the cursor jumps around like it's being held by somebody having a seizure.
  3. Originally Posted by lordsmurf
    Here and I thought it was me all this time
    Now that i know it's that sensor bar, I'm going to get another one
    Originally Posted by jagabo
  4. Why don't you just cut out the section the wabbit chew and join it again?.
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
  5. I bought a wireless one from Intec/Intex .. whatever the brand is. Its pretty good.
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Yeah I was going to suggest a wireless model if you were going for a replacemnt.
    I still have my original sensor bar. I am glad it had a really long cable. Most of the time standard cable lengths on any oem external stuff is usually way too short.
